Any Tire Pressure Gauge Recommendations?
Search only yielded results from 2003-2004 😅. I had a VDO analog dial that gave out and need a new one that actually works and lasts. Would like a high quality for the shop and some less expensive to keep in the vehicles. Thanks!
I've had this for forty years.
Drager, made in Germany
ebay
For the cheapest gauges it's hard to beat the Milton pencil type gauges. They are still made in the USA if that's of interest. These are what I keep in the vehicles.
I've also found Jaco gauges to be pretty good.
What's your budget?
I assembled two gauges earlier in the year. One, using a Ashcroft digital gauge and Auto Meter hose. And another using an old Ashcroft gauge from the '50's or '60's that I found in the garage. The old gauge is very heavy duty. The metal in the case is far thicker, and the internal components are strong and heavy. "They don't make them like the used to" holds TRUE. I checked it for accuracy, and it's within 1 psi at 35 psi. Good enough for me.
I have this Jaco Elite in my Accord glove box. Goes to .1psi increments. Used weekly to check 6 vehicles. All of mine are used in conjunction with a tire depth gauge like this, used frequently. If center is wearing faster 1-2psi need to be lower. If edge treads are lower 1-2 need to be added. I check across full tread in 4 spots on each. For me that equals 4 cars with +2 over door placed, 1 at door placard, 1 at -2 from door placard (but has slight oversized tires).
The fill hose version on my compressor in garage.
5 vehicles have the Slime Sport Digital that has worked for MANY years of flat even tire wear. The Jaco was new to me late '22. Slimes only show to .5psi but are normally within 1psi of the 2 Jaco's. Works for me when out and traveling, kids at school etc. All glove boxes have at least 1 pencil gauge from who knows how long ago. I gave many cheaper pencil ones away that came at/with car things. They worked, normally close and even if off by 2-3 psi are still better then the ones the people didn't have at all. At least they check now with something or if a TPMS light comes on.
$13.99 for 10 of them covers all cars and give away. There are nicer digital ones. I also have as well as a caliper/micrometer if I really feel like getting crazy.
The tire pressure monitor in my truck runs spot on with my analog gauge that I keep in the garage . I pull up the display a couple of times a week and if any of them need topping up I use the analog gauge along with the compressor .
If you're going under twenty bucks get a digital one, they're easier to make cheaply and accurately.
Analog ones get banged out of whack... and how would you know without a cross reference?
