Just posting to hear your thoughts on using a mid SAPS oil instead of a high SAPS oil in a 2016 VW Passat EA888 Gen 3 engine. This engine is both turbocharged and direct injection.
Both the owner's manual and the underhood sticker states VW 502 oil spec.
Here are are two US market oils that both meet the required VW 502 spec (needed to be safe with the new car warranty).
The very common Mobil1 0w-40 FS which is a high SAPS oil
and the oil I am considering changing to Castrol 5w-30 c3 which is a mid SAPS oil (
My understanding is that the lower SAPS oil would be better than the higher SAPS oil for a couple reasons such as lower chance of cat poisoning, lower chance of intake valve deposits and lower chance of LSPI.
The only two negatives I can think of is the lower SAPs oil has lower TBN and would be susceptible to quicker degradation if subjected to higher sulfur gasoline (and might therefor require shorter drain interval) and this lower SAPS oil costs a bit more than the cheap Mobil1 0w-40.
I know that a lot of people say the engine will last forever and the car will rust away before the engine goes, etc. But I want to be sure this engine lasts a long time without unreasonable maintenance such as cleaning the intake valves or replacing the cat, etc. Also, I like reasonably long oil change intervals. Owner's manual states 10,000 miles, and I've been going between 8000 and 10,000 miles and would like to continue that if I make the change to the Castrol 5w-30 C3 mid SAPS oil.
Any thoughts or ideas? Am I off base here or splitting a hair too fine?
