I have a different idea-disable the fuel pump and fog the engine through the air intake while cranking it over. That way the fuel level doesn’t drop. Bag off the air inlet ahead of the air filter if possible too, keep the mice out!
Is that not the same whether it starts today, next week, or two years from now?no if the oil pump gets enough air in it, it might not prime for a long time cranking. it depends how much ckearance there is. Similar to what happens on a new build.
I would have drove it to get it full hot, then do the oil & filter change - drain oil fully by drain plug. Then drive it again after the oil change to fully hot. Stop by the gas station close to home on the way back, fill up the tank with fuel stabilizer added. Then drive straight home and park it. Disconnect or remove the battery and/or keep it charged since 24 months is a pretty long time to sit.Changed the oil on this 2012 S500 earlier this week. The car had been sitting for 60 days. The car will likely sit for the next 24 months.
I have seen old car revivals where they sat for years and the oil pump wouldn't prime. For 2 years it is probably unlikely but definitely not out of the question. Also what is the point in changing the oil in the oil pan if you're not going to run it through the engine?Is that not the same whether it starts today, next week, or two years from now?
Memory is the reason I changed the oil. My memory is not so well. I change the oil in all my vehicles in the last few weeks. One less thing I have to try and remember. I know when I return to the vehicles they all have fresh oil, and a full tank of gas and Stabil.I have seen old car revivals where they sat for years and the oil pump wouldn't prime. For 2 years it is probably unlikely but definitely not out of the question. Also what is the point in changing the oil in the oil pan if you're not going to run it through the engine?
Any reason I should circulate the newly installed oil?
Wish I would have. I have departed from the vehicle. Hopefully home at Christmas and will start her up and get that oil moving. If @Pablo gets sick of the rain, wind, clouds, cold in Washington, he can slip away to New Mexico for some dry sunshine and help a buddy by starting the S550.Its an easy way to quality check yourself, its simple, effective and gives you assurance.
The phone has memoryMemory is the reason I changed the oil. My memory is not so well. I change the oil in all my vehicles in the last few weeks. One less thing I have to try and remember. I know when I return to the vehicles they all have fresh oil, and a full tank of gas and Stabil.
