Any place to buy a quart of cheap 2-cycle oil?
Mn
I'd like to buy a cheap quart of 2-cycle oil for my leaf blower, chainsaw and other lawn equipment. Don't really care about the brand name. But it seems most stores sell the smaller bottles, which end up being expensive, or they sell the expensive brands. I did find that Menard's (I'm in Minnesota) lists on its website that it has a quart of Quaker State 2 cycle oil for air cooled engines for $4. However, after going to two of their stores, they are out of stock. Anyone else have a good source for cheap 2 stroke oil in the larger sizes?
San Diego, CA
The "W" in "TC-W3" means water-cooled thus lower temps and I'm sure people have lots of opinions but I wouldn't run it in my trimmer or chainsaw. You want something designed to lubricate at the higher temps of an air-cooled engine. OP: If you can't find a quart or more in a single bottle just consider buying a case of whatever oil suits your fancy. Pretty much every mfg of 2 stroke lawn equipment has one and I expect they're no better than one another. Just buy a six pack or a gross or whatever the retailer gets. You probably won't get it locally but if you really want it you can get a 5 gallon pail of Stihl synthetic oil.
WI
Studly, You may want to give Fleet Farm a try, as they typically have a reasonable selection of air-cooled 2-cycle oils to choose from. For example, the Mystik Sea & Snow oil is JASO FD rated and costs $4.79 a quart. While most users are likely using this oil for their PWC and/or snowmobile, the FD rating suggests it should work well for the applications you mention above. https://www.fleetfarm.com/detail/my...lend-engine-oil/0000000238546?bc=Mystik# http://docs.mystiklubes.com/msds_pi/M20089.pdf Belker
As has been mentioned, look for JASO rated oils. Don't buy TC-W3 stuff for your OPE unless is specifies its use. Lucas is pretty cheap, the Mystik that's mentioned looks promising, motorcycle shops have quarts of JASO rated oil for $10 or $11/quart (Yamahlube 2R or 2s for example). I agree that trying to buy high quality oils from Home Depot is expensive. You pay for convenience with those small bottles. My local mower store sells Echo Red Armor for $3 less per 16 ounce squeeze bottle than does Home De;pot so look around and see if you can give a small business owner some business. I know we're getting a tad off of the cheap quart topic but Amsoil in quarts is only $10.10 if your local dealer will sell to you at preferred pricing (mine does) so it never hurts to look around.
Near the beach in Delaware
Even if the little bottle is expensive per ounce, it typically makes a gallon of fuel. Which for many people will last a while for chain saw or blower. If you only need to buy one or two of the small bottles per year is that a big deal?
maple ridge, bc
tractor supply https://www.tractorsupply.com/tsc/product/countyline-16-oz-40:1-2-stroke-engine-oil?cm_vc=-10005
NE,Ohio
probably wasted more money driving to stores than just buying whatever. I prefer Echo red armor at home depot.. but they carry other brands cheaper.
Studly
Mn
Originally Posted by 65f100
At many farm stores you can find Mystik JT-4 2-Cycle Lawn and Garden Engine Oil.
Originally Posted by Belker
Studly, The Mystik Lawn & Garden oil that 65f100 mentions above is JASO FD rated and is $4.79 a quart at Fleet Farm. This oil seems like a very good fit for the applications you list above at a reasonable price. See the links below for more information. Belker https://www.fleetfarm.com/detail/my...n-engine-oil/0000000235478?Ntt=2%20cycle http://docs.mystiklubes.com/msds_pi/M20084.pdf
Thanks for the great tips, everyone. I do have a Fleet Farm down the road and will see if they have the Mystik oil in stock. And now I have lots of other places to try if that doesn't work.
South Carolina
Originally Posted by deoxy4
Autozone STP brand 2 cycle oil- $3.99/quart.
^this is what I use. Works great and always convenient when I'm checking the clearance items at AZ.
Kentucky
Don't run the outboard oil in an air cooled engine. Sure it will probably work and not blow up on you, but why not run transmission fluid in your engine crankcase while you're at it? Probably not going to blow up either, so it must work..? Use something with a JASO-FD or ISO-L-EGD rating. Most any 2-stroke OPE manual will recommend these lubricants. They are easy to find (though not as easy as the outboard stuff) and are designed to work in air cooled engines. Though I am no fan of Lucas products, I use their 2-stroke semi-synthetic 2-stroke oil which has the aforementioned ratings as it's always available at all the chain autoparts stores. It's not the cheapest oil in town @ around $7-8 per quart, but I swallow the price since it lasts me a couple years or more. Mystic makes a good one as well that can be found at a lot of farm/fleet type stores. I've also used Amsoil Interceptor and Amsoil Saber with good results, both are intended for air cooled engines.
