Originally Posted By: Kira
What I can tell you is that the salespeople wouldn't commit to an answer regarding matched tires on their CX system.
I don't even know what you mean.
Are you asking if Mazda requires the user to swap all 4 tires on an AWD vehicle at the same time to keep the overall size of the tires the same?
Here's what I can find in the 2014 CX-5 owners manual online:
Quote:
Replace all four tires at the same time:
Replacing just one tire is dangerous.
It could cause poor handling and poor braking resulting in loss of vehicle control.
Mazda strongly recommends that you replace all four tires at the same time.
Tires and Tire Chains
The condition of the tires plays a large role in the performance of the vehicle.
Moreover, to prevent adverse effects to the drive assembly, please note the following:
Tires
When replacing tires, always replace all front and rear tires at the same time.
All tires must be of the same size, manufacture, brand and tread pattern.
Pay particular attention when equipping snow or other types of winter tires.
Do not mix tread-worn tires with normal tires.
Inspect tire inflation pressures at the specified periods adjust to the specified pressures, and initialize the tire pressure monitoring system.
NOTE
Check the tire inflation pressure label attached to driver's door frame for the correct tire inflation pressure.
Make sure to equip the vehicle with genuine wheels of the specified size, on all wheels. With AWD, the system is calibrated for all four wheels being of the same dimensions.
BC.
