I've owned about 20 cars from model year 1977 to 2010 and every single one has operated like this.
Turning on the AC when defrost is selected isn’t new.
My 1977 Oldsmobile did the same thing.
So, I don’t know when you could last get a car that works the way you want.
Perhaps something from the 1960s?
If the few minutes the compressor is engaged is going to kill your a/c system, it was going to break down anyway.I don't like the idea of wasting my AC system and gas when it is not needed.
Any ideas on how to remove "idiot proofing" in my van's climate control?
Every vehicle I've had did the same, but you could select recirc and A/C both off if you wanted. In this instance I think Toyota's thinking might be to give you the most efficient defrost since that's what you're asking for. (many people are too stupid to realize that's the best option.)Yeah, I guess I should clarify. I WANT the AC to be optional, not fully disabled. It's nice to have when there is a lot of moisture to clear quickly. For the vast majority of driving in traffic and around town, it's overkill. I also hate the idea of running the AC compressor on cold mornings when I'm trying to heat up the windshield to melt ice. AC runs the cold engine harder and hurts the temp of the air hitting the glass.
And people wonder why after not using the A/C for 6 months over the winter, it doesn't work on the first warm day in spring. Seals shrunk and freon leaked out.Stop trying to re-engineer the system and let it work the way Toyota designed it. It was for a reason. And as others have stated, cars have been made to operate in this manner for many years.
Most people here feel you're trying to fix something that isn't broke. Saying, "it just makes it take longer to heat up as it fights the heater core" isn't true as most compressors don't kick in below 40F anyway, and if they did, the longer time to heat up is marginal. And saying, "I don't like the idea of wasting my AC system and gas when it is not needed" is also flawed as the amount of extra gas you use idling might be a few cents. If it really bothers you, put an on/off switch in the dash wired to the compressor so you can keep it off at will.And saying I should not mod it and keep it stock because Toyota knows best? Come on, dude. That's pretty obtuse isn't it?![]()
Honestly I’d quit worrying about it. Most of my GM cars since the late 90’s-early 00’s, turn on the A/C compressor whenever I use the floorboard heat selection. Incidentally, I haven’t had an A/C system failure in decades. The compressor running is a good thing.Yeah, I guess I should clarify. I WANT the AC to be optional, not fully disabled. It's nice to have when there is a lot of moisture to clear quickly. For the vast majority of driving in traffic and around town, it's overkill. I also hate the idea of running the AC compressor on cold mornings when I'm trying to heat up the windshield to melt ice. AC runs the cold engine harder and hurts the temp of the air hitting the glass.
