Any harm in hooking up trailer lights backwards?
So apparently I don't pay attention to how things go together like I used to. Then again I didn't count on not being able to decipher the color of the wires on my trailer. They were painted black and even after removing the paint the colors are about the same. Is there any harm in hooking up the brake like wire to the running light bulb accidently if I have them backwards? The other issue is I have a ground issue where the lights only seem to ground through the trailer hitch ball even though I grinded the paint down to bare metal on the tongue and both tail lights.
Originally Posted by tundraotto
only if the trailer brakes come on with the lights.....
I got ya. The brakes would be on the entire time the running lights are on. This trailer has no brakes anyways. Obviously I'm going to switch them around if I have them backwards.
Pretty sure the brake filament is brighter than the tail light filament, so it does make a difference. Hook a dedicated ground wire up thru your wiring connection that goes from the light bulbs/lightbulb sockets thur the connection to a known ground on the truck.
Why not just test them as installed and if they work properly, they work properly. Switch wires if they don't. You could also trace the wires back a bit to where they hadn't been painted.
Most bulbs don't care about which way the current is flowing.
Other than the wires causing a direct short what makes you think damage would occur
I don't think they were concerned with color coding when they built this trailer, otherwise I would have done that.
It's only the passenger side that looks the same. Somehow the brown and green look the same.
Plug in the truck, turn the running lights on, then touch what you think is the brown trailer wire to each light wire. Use the one that lights up dim. If the "brown" wire seems dead, try the other one. By elimination, the other wire is the turn / brake.
Always run a network of ground wires (standard color is white) to each light and the truck plug. Do not count on grounding through the frame.
Mk378 do I have this right? I have a ground wire on each tail light attached to clean shiny metal on the trailer and then one ground wire that.goes from the truck plug to the tongue of the trailer, also connected to clean shiney metal. It still seems to only be grounding through the ball though.
Run a ground by wire all the way from the truck plug to each light. You don't need an individual wire for each light, you can tee them into a common wire. Don't involve the trailer frame at all.
It is also possible that the ground socket on the truck is not grounded to the truck. That would cause what you're experiencing. With the lights on, the ground wire in the trailer plug should be zero volts measured to the truck frame.
