Any Ford Techs? 04 Mountaineer binding, broken dif
Detroit, MI
Have an 04 Mountaineer 4.0 awd. The truck would bind bad when turning, moreso at slower speeds. The rear differential exploded. Replaced that. Then something broke in the front differential and put a hole through it. Looking at Ford bulletins, they mention ABS binding. The rear diff and left front are reading correctly. Rt front is bad. Any idea what is going on with this truck? Could the ABS sensors being bad actually cause this sort of damage? Looking for some insight from someone who may see this type of problem on an Explorer or Mountaineer.
Thanks.
