Any downsides to the Lexus GS series?
Elkins45
Site Donor 2026
Northern KY
I like the idea of a GS over an LS because a longitudinal V engine is easier to work on than a transverse one. I’ve been looking at the local market and see a few 15-20 year old GS 350 and GS460 for sale at not outrageous prices. Is there any reason not to consider one as an occasional use vehicle or a daily short-tripper for my wife?
I would avoid a 300 or 330 because I don’t want to do the timing belt service.
They suck the gas. Our 2013 GS 350 F Sport is a great car!
Close friend of mine has a 2013 gs350 that he absolutely loves. He wanted something pleasant to be in for his hour commute each way and it fit the bill perfectly. I helped him put in around 2000 of parts in it and he had another couple thousand in ac repairs over his 3 years of ownership. It appears quality aftermarket parts are more limited than some other brands and the oem were not cheap. Even with the repairs he wont get rid of it until its wrecked.
You mean ES?
I had a 2016 GS350 F Sport that was a fantastic car. Personally, I prefer the looks of the '13-'15 cars as mine and the latter cars have the weird Predator looking grill. Aside from middling fuel economy (low to mid 20s on the freeway) it's a great car that makes great noises and if you get one with the Mark Levinson Sound it's awesome. The holy grail - for me - would be a gentlemanly old man spec of a '17 or '18 Ultra Lux package RWD in white over tan leather.
A good friend has had a bunch of the ES models. Nice smooth cars, not just improved Camrys.
I think Lexus makes a good car, but don’t fall into thinking that nothing ever breaks, because while they are well made these are now older vehicles. And they are luxury cars so parts are expensive. so get a good PPI. Finally I drove a GS a long while ago and was impressed but if you care less about driving dynamics there are a lot of ES models owned by older folks who drive less miles - you might get a better example going that route.
Good luck with the search!
My FIL had a GS around 2012ish. I drove it a few times and liked everything but the lack of headroom. I'm 6'5" but can easily fit in a Kia Soul but not the GS.
I had a 2014 GS. Bought it thru Carmax and their warranty replaced all four door lock motors, sunroof motor, and seat belt retractor. It sucked fuel in town but was ok on the hwy, 21 in town and 27 highway. I downsized to 17” wheels which improved it in every way. It was a solid, heavy vehicle and was a pleasure to own. Stock stereo was fabulous, pre-touchscreen display was useful, and if you drove it hard it would absolutely boogie. GS in my opinion is a rare breed of vehicle. The only nuisance was a rattling moonroof, fixed with shin-etsu grease around the rubber seal.
As I don’t need that much V6 power, and frankly it scared me a couple of times, I’d be ok with the lower trim 4T, which is a slugbus in comparison, but anvil reliable.
These cars are awesome which is why they're expensive used. You get what you pay for. You get a bit of sportiness, a bit of power, a bit of luxury, and excellent reliability. I would recommend against a rear wheel drive F Sport trim as they burn through tires fast and can have squeaky brake issues for some.
Thats a good point from @bighead2586. I did have to chase brake nuisance squeaks. Mine was just the standard 3.5L, which is a bit of a legend in itself - it’s a pretty hot motor from what I read and in demand from wrecked ones for motor swaps.
The brake rotors are large in these, and driven like a normal person dont get as hot as say they would in an accord or Camry, driven equally. Especially if aggressive pads are used, they may not spend much time at healthy op temp. There also aren’t a lot of mfrs for that rotor. Centric worked well on mine. I used element3 pads at the time as they had been my goto - which is where I learned that car doesn’t need GG-rated pads. I had to drive it hard every once in a while to keep them bedded.
Yeah mine was a 2013 RWD F Sport the squeak wasn’t bad for me. I’m in a tropical climate which helps. I only got 15-20K out of the rear tires with the staggered setup. Non F Sports had smaller quieter brakes and square tire setup.
The horrible brake squeal issues stem from the Textar pads. The Advics pads solve the problem. Full disclosure, it drove me crazy.
The rear tires wear is true, partially because you can't rotate them.
I have a 2015 GS 350 non-F sport AWD and absolutely love it! Bought it CPO in 2018 off lease with only 11,800 miles from the original leasing dealer. It now has 95,000 miles. Aside from normal maintenance it has only had one mechanical problem of a leaking rear differential pinion seal. $500 repair I was not expecting, but that has been it. Plugs replaced by me at 60K (per manual). Originals were perfect. Coolant at 10 years. All fluids replaced in timely fashion. Original brakes were squeaky when cold and only lasted 40K front and 45K rear. Replaced with Raybestos Element 3 pads and rotors. Dead quiet, dust free and braking is better than the Toyota originals. At 95K they are about 1/2 gone.
The car still looks and drives like new. Very quiet with not squeaks or rattles. Requires 91 octane gas and economy is not up to current standards. I get consistently 19-20 mpg city and on long highway trips at 70 mph 26 mpg.
I did add CarPlay using the BeatSonic module (there are others available now) which has been perfect and makes the car as updated as I would like electronically.
