Some of you here may know I put a new water pump on my Dakota this past weekend. I have a post about it here:
https://bobistheoilguy.com/forums/threads/play-in-water-pump-shaft-bearings.147929/
My truck runs fine now, the temp gauge is right where it should be, oil pressure is good, no noises or vibrations or anything like that. It did fine coming to work today at 72 mph on the interstate.
What the truck does do though is it has a lot of condensation-white smoke out of the tail pipe when it is first started. After I drive about 2 miles or so and the engine warms up, the smoke stops. Before I installed the new water pump it did that too, just not as much quantity of smoke and it stopped after driving less than a mile. I know some amount of white condensation out the exhaust is normal when it is cold and/or humid outside. But I am a little worried that it happens now for a longer period of time with a larger amount of condensation smoke.
I think everything is OK and the reason this is happening is
1. I have a better water pump now that is moving the correct amount of coolant through the engine.
2. I think that the concentration of coolant to water I used is less than what I drained out when I R&R'd the water pump. I think the old coolant mixture had a lot more water in it so it heated up faster, and the condensation smoke stopped sooner.
When I added coolant yesterday after installing the new water pump I added a whole gallon of plain regular green coolant, then about half a gallon of about a 50/50 mixture of coolant and distilled water. I ran the truck for a long time, topping it off as needed then checked it again last night and added a little more 50/50 mix. Then this morning I added about half a cup of plain distilled water because the level was just a little low in the fill neck. My coolant fill is in the middle of the upper radiator hose.
I am concerned about the condensation smoke and I greatly appreciate any info you guys may have on it. Thanks.
