The company I work for hauls antifreeze in bulk. We had been using aluminum tank trailers almost exclusively. The consensus was that the antifreeze is used in engines with aluminum components there should not be a problem.
In the past few months, several trailers had to be put out of service, due to pitting and general metal loss. There are published minimums for the thickness of the barrel.
After some investigation, we found the PH of some antifreeze is rather high. One 50/50 premix had a Ph of 11. Most online sources say anything over a Ph of 9 will damage aluminum.
So, how is it we can put the stuff in cooling systems with aluminum components and not damage them?
