Anti Drainback Valve in Gen 6 (2010-2011) 4 Cylinder Camry
Since the car uses a drop-in filter, I was wondering if there's an anti-drainback valve (or equivalent) incorporated into the system. Anyone know?
Next time you change your oil, empty the sump completely. Then open the cartridge housing and see if any more drains into the sump.
Those have the cartridge filter that is vertical on the front passenger side of the engine right? More likely than not, it doesn’t need a adbv because it’s going to always have oil in the cartridge
And gravity will pull the oil down from inside the engine, like filling and overflowing a glass on the table. Filter full means nothing if its backwashed from above. Where is the filter in relation to all the oil passages above it?
No ADBV that I can see. Didnt notice any in the engine either.
Baxter adapters also states that there is no adbv
https://baxterperformanceusa.com
