Hello everyone. First post here. I try my best not to make these types of threads but I can't seem to find anything definitive yet.
I recently bought a used Jeep with a 4.0 and
In my past cars, I have used Mobil 1 with a Mobil 1 filter without issue and have been happy with it. Initially, I had planned to do the same with this car but read that these engines are old technology and really like oils high in zinc/ZDDP (?????). As I understand it, modern regulations demand most oils to have very little ZDDP.
I've read of people using Shell Rotella for it's high ZDDP content but have also read that the oil is designed for heavy-duty cars without catalytic converters as the ZDDP is bad for the cats.
Further, I've also read of people using Mobil 1 high-mileage for it's higher ZDDP content than the regular Mobil 1 line. I was under the impression that high-mileage oil usually contains seal swellers and etc. with can wear down otherwise good internals. I don't know if high-mileage oil should be reserved only for really old cars on their last leg of life?
Anyway, I was just wondering if any of you oil gurus can make a recommendation on what to use. I'd like to stick to one brand to use from here on out.
Also, if there are any Jeep peeps here, is the factory 10w30 spec along with the stated 6 quarts both optimal? Only asking because in one of my previous cars it had been known that a slightly thicker oil along with more quantity was actually more beneficial than factory spec.
Thanks!!!
Thanks!!!
