Originally Posted By: ChemicallyChargd
Well to clear some confusion, I won't argue zinc benefits flat tappet rides, but there's some confusion as to why or how. Zinc is not in any way nor does it form any kind of magical coating on parts, a high zinc level will only allow the motor oil to last longer before it's supply of zddp is depleted. Using a motor oil that has such a zinc level that it can't be API certified or adding it in has been proven to do more damage to your cat's, far more damage than its worth, like trading your dollar for a penny. So essentially don't worry about the zddp, if it's API certified it's got plenty zddp to last through a 5k-7,5k mile OCI, it would only concern me if I were considering 10k+mile OCI' s(what I do currently). Shear strength is the single most important thing you want, if this sucks, it defeats the point of a good additive pack. Take it all the way and use their 0w-30, the viscosity at room temp is closer to the operating temp viscosity, which means less viscosity modifiers and a higher total base stock % (less additive means more actual oil), both being the same op. temp viscosity, the 0 will get moving quicker at lower temps than the 5. Remember the problem with oil is it thickens when it cools, NOT that it thins when it gets hot, the 0w thickens less, if nearly all wear is in those few seconds at cold start(after its warmed up the oil can get moving almost instantly and can be started/stopped with no where near the wear of a cold start), and the 0w gets to your bearings faster, it's the intelligent choice.
-SRV
I ran Mobil 1 Advanced Fuel Economy 0w30 in my TJ from July-March this past year and it did fine on it. After looking on here though, I saw that for the temps that I see here Texas, at start-up, the 5W and 0W viscosity were [censored] near the same. It wasn't until extreme sub-zero temperatures that the cold cranking advantages of the 0W came in to play. Because of this and the lower zddp levels in Mobil 1 Advanced Fuel Economy, I switched back to Mobil 1 5w30. Has the same viscosity in the temp ranges that my Jeep will see and a bit more zddp.
