But this is my hang up - it's often the case. Yes, all the science shows that you get more wear using the thinner oils and less efficient oil and air filters. But, the question for me is whether a vehicle with a less efficient filter(s) and thinner oil run well with no measurable ill-effects for the normal time folks own them with these vs. using thicker oil and higher efficiency filters? I'd say sure. So then what does it matter? That is the crux of this (for me) and the testing is hard to do to ever show it. 10 years/125K on 5W20 and a K&N air filter in my Ford Focus. No oil consumption. Great running car. Is tuned for more power. Spent a lot of it's life in low-load highway commuting but also has had the snot beaten out of it by my teenage son. So did I do worse b/c of it than if I used a Motorcraft paper air filter and 5W30 over that time? Did I gain an marginally tiny improvement in mpgs that over 10 years adds up to something not so marginally small?That seems to be the part people don't seem to comprehend ... seems they think just because it "seems top still runs good" that it must still be in stellar shape. That's not always the case.
So my summary of all these recent threads (before it gets locked which I'm sure is about to happen in 3...2...1...ahhahaha) is...does the increase in wear (the engineering/science proves this beyond a reasonable doubt is true is what I read here) from running an oil with a lower viscosity matter in the "real-world" that most of us live in?
