I've been working on a problem I have with my E-150 for quite some time now, and just had another mechanic toss in the towel after a week of head scratching. I have an engine surge problem when the engine is restarted hot, it will search for an idle speed until the gas pedal is touched, then stabilize. It starts fine cold although seems to lack a little power until it starts to warm up. Sometimes taking off it will stumble, then race up, as the computer compensates. It is a stick shift, and it is not driver error, confirmed by several others driving it. At times when the AC compressor kicks in it will stumble as well. This doesn't always happen making it more frustriating!
After about 5 mechanics from three different shops went through this van here is what is NOT wrong.
We are 100% certain there are no vacuum leaks, verified now by 3 smoke tests, propane, and carb cleaner testing.
There are no codes
The IAC has been swapped out with others with no improvement, same goes for the TPS.
Throttle body is clean, gasket is new with a Ford updated version.
Gas filter is new, as is cap, rotor, wires, plugs and air filter. Engine timing is spot on. Ignition module is new.
02 Sensor, MAP, CTS, Air Temp Sensor, fuel pump, pressure regulator, are either new or up to spec.
Cat converter is fine, and emission testing is fine.
ECM has been swapped out with another with no improvement.
It responded well to fuel injector cleaning via the rail, but it still has the surge and stumble on occasion when taking off. It was fed MMO via an inverse oiler for many years, so the MMO didn't work its magic on maintaining the injectors.
Here's what I think. The IAC has had a few revisions over the years, the IAC units I've swapped were all FMC parts not knock offs. However I haven't tried an updated version. All mechanics feel it is safe to rule the IAC out. I even installed a spacer plate under the IAC as per a Ford TSB, another waste of time.
All Data has TSB's that report to injectors as being a possible problem, along with the IAC. But once warmed up and moving the van runs flawlessly. The situation is more of a PITA that I want resolved and something I've been told I might just have to live with.
Since this van is not considered a beater I don't mind tinkering, to a point that is. I'm leaning toward injectors, however there is 3.5 hours labor to R&R, and a cost of about $75-$100 each, not something I want to guess at. I won't use rebuilt injectors or injectors that went to a service, because I'm sorry to say I don't want to have problems with them and toss 3.5 hours time out the window. If rebuilt injectors are anything like rebuilt carbs no thanks!
Should I try doubling up on RL FI cleaner for a tank or two, then maybe a mega dose of MMO? Perhaps a third injector cleaning via the rail? Or bite the bullet and live with it, since no one for sure including Ford techs will guarantee replacing injectors will fix this thing?
This should challenge some of the more technical guys here since it has left some of the best area mechanics and myself scratching our heads!
As always thanks!
There are no codes
As always thanks!
