so at the risk of beating a dead horse....
I've searched and have seen a lot of info, but beating around my question/situation.
my Subaru. the manual says to use ATF in the power steering if its an automatic, but PSF if its a manual. so, my guess to this is to avoid multiple fluids in a shop or home as the pump has no difference for manual or automatic. so if i want fluid, i should be able to use either, and/or get a PSF that works with "any" fluid, such as the lubegard PSF it has in it now.
that's one "issue" down.
But now i want to replace fluid in our 2000 4runner. it calls for ATF. Shure, i can go get some maxlife atf and continue but here goes the overthinking......
looking at redlines offerings, they suggest their atf, I believe D4. cool, and out of curiosity, i look at the PSF offerings and see that it is compatible with DEX 3 which should also work. which one should one go with?
so, if there are so many PSF products that are compatible with DEXIII, why should one put one fluid or another?
help me stop the overthinking! it would be nice to just have one container of Lubegard or redline psf for all my vehicles.
