I have been looking at bypass setups. The amsoil setup is too expensive for me right now. Baldwin has a setup that can be put together. It would consist of either a baldwin b50 filter (5inches long) or a b164 filter (7 inches long) and a head that baldwin sells that fits the threads of these filters. The kicker is that both filters have an orfice that regulates flow built into them, so only plumbing needed would be straight from the oil sending unit to the filter head and back to the valve cover. The filters are around 10 dollars and are listed as 2 microns nominal and 12 microns absolute.
Might not do quite as good a job as the amsoil or other setups but should cost about 1/2 of other setups and be much easier and cheaper to get replacement filters.
Dan
Dan
