Quote:
It it does, it can't be labeled as a straight SAE 30 per J300. It's non-Newtonian and has to be labled as a multi-grade if it has VI improvers in it.
We had this discussion a while back.
It was never resolved to my satisfaction. As far as I can tell, the only requirement for a mono grade oil is that it only meets a single grade classification on the SAE J300 chart.
It may be typically that mono grade oils don't use VII's, but I don't see that as an absolute requirement. Do you have any relevant references you could post?
The best I could google is this …
Quote:
Railroad Engine Oil is Changing.pdf
to develop what is now known as
Functionalized Monograde Functionalized Monograde (FM) is a finished oil formulation that provides excellent wear control, shear character-istics and viscosity retention that con-tributes to longer oil life and reduced maintenance costs. The attributes of the FM — oil consumption savings achieved via the introduction of multi-grade railroad engine oils are main-tained;
an optimized viscosity index improver dosage; low SAPS (sulfated ash, phosphorus & sulfur); and a fresh kinematic viscosity of 14.6 cSt at 100 C, — results in cost-effective finished oil formulations.
My take here is that they want a low SAPS oil for railway use (emission requirements), which means using GII base oils. One could take a 12.0 cSt GII and add a little VII's to get a 14.6 cSt oil.
Quote:
I am guessing that you blend motor oil or have done so in the past.
No actual blending experience. But I sometimes think I spend too much time reading about oils.
