Part Number: 51036
UPC Number: 765809510364
Principal Application: GM Cars + Trucks (80-05), Mercruiser, Volvo-Penta
All Applications
Style: Spin-On Lube Filter
Service: Lube
Type: Full Flow
Media: Paper
Height: 4.828
Outer Diameter Top: 2.921
Outer Diameter Bottom: Closed
Thread Size: 18X1.5 MM
By-Pass Valve Setting-PSI: None
Anti-Drain Back Valve: Yes
Beta Ratio: 2/20=12/26
Burst Pressure-PSI: 325
Max Flow Rate: 7-9 GPM
Nominal Micron Rating: 19
Gasket Diameters
Number O.D. I.D. Thk.
Attached 2.734 2.430 0.226
The 51040 is what Wix says is spec's
Part Number: 51040
UPC Number: 765809510401
Principal Application: GMC -Chevy, Monza, Corsa Venture,Shilouet,S10,Blazer,Pontiac Sunfire,Grand Prix,Grand AM,LUV Bonneville,Malibu LS LX,Impala 01-,Cavalier,Camaro, Corsa, Aztek,UPLANDER3.5 SUZUKI Forenza 04- , Reno 05- ,
All Applications
Service: Lube
Type: Full Flow
Media: Paper
Height: 3.404
Beta Ratio: 2/20=15/31
