Another larger oil filter?
michigan
Is there a larger oil filter I can use on a 2000 Olds Bravada? And if so do you know what vehicle it originally fits? I only use NAPA gold filters and would like to just walk in and tell them I need a filter for (Make and model) of car and call it a day without having to cross reference anything. I have seen bigger bottles of aspirin then the oil filters they put on these trucks!
I assume it is the 4.3 Vortec engine. I think that is the only option for a 2000 Bravada. The standard filter would be a Delco PF-52. That is not that small of a filter for 4.3 V6. It is a small diameter and somewhat long filter. Due to the small diameter it may be hard to find a larger filter.
It is a 4.3 liter...that is the only engine available in a second gen s10 series. It is also a very small filter considering my suburbans 350 filter is twice as big. A 4.3 liter is essentially a 350 minus two cylinders. Minus two cylinders does not justify making a filter that is twice as small in my opinion. Looking for a longer filter as there is lots of room.
Can you replace the remote filter mount with one that has a more common thread size like 3/4-16? I think yours is 1.5mm x 18. That and the specification for a filter without an internal bypass doesn't give a lot of choices.
FWIW, I had a 2000 Blazer 4 x 4 with the 4.3 Vortec, and just used standard size WIX (or the NAPA Gold clone WIX) and had plenty of oil pressure.
Part Number: 51036
UPC Number: 765809510364
Principal Application: GM Cars + Trucks (80-05), Mercruiser, Volvo-Penta
All Applications
Style: Spin-On Lube Filter
Service: Lube
Type: Full Flow
Media: Paper
Height: 4.828
Outer Diameter Top: 2.921
Outer Diameter Bottom: Closed
Thread Size: 18X1.5 MM
By-Pass Valve Setting-PSI: None
Anti-Drain Back Valve: Yes
Beta Ratio: 2/20=12/26
Burst Pressure-PSI: 325
Max Flow Rate: 7-9 GPM
Nominal Micron Rating: 19
Gasket Diameters
Number O.D. I.D. Thk.
Attached 2.734 2.430 0.226
The 51040 is what Wix says is spec's
Part Number: 51040
UPC Number: 765809510401
Principal Application: GMC -Chevy, Monza, Corsa Venture,Shilouet,S10,Blazer,Pontiac Sunfire,Grand Prix,Grand AM,LUV Bonneville,Malibu LS LX,Impala 01-,Cavalier,Camaro, Corsa, Aztek,UPLANDER3.5 SUZUKI Forenza 04- , Reno 05- ,
All Applications
Service: Lube
Type: Full Flow
Media: Paper
Height: 3.404
Beta Ratio: 2/20=15/31
The Fram number for an oversize filter is PH3980.
Some filters use this numbering system. Use what ever brand you
like, just convert the 3980.
