I’ve used High Mileage oil in the past. Once had an old 89 Chevy Cavelier that had 213k on it when I gave it away to someone in need. I only used Valvoline Maxlife in it from 50k up to the 213K I had on it. I’m sure I would have gotten the same results from any oil. Right now I have two cars, one with 160k, the other with 110k. Every once in a while I noticed the used oil analysis coming back from people using Maxlife and must say that I’m impressed with the add pack. The oil manufacturers web sites promoting their High Mileage oil discuss how clearances become looser over time due to wear of the internal parts and how more protection is needed to prevent burn-off. But, will NOT using a High Mileage oil cause the inevitable wear of an engine to increase at a faster rate? I want to know if there is any truth needing these products.
Also, for the simple fact that my higher mileage vehicle leaks a little oil, I am considering a High Mileage oil for that reason alone and I’m so darn confused between using Maxlife or Pennzoil High Mileage. I use Pennzoil conventional right now, and that’s the brand that I love and prefer. I’d sure as heck like to know if Pennzoil High Mileage is actually a blend like Maxlife claims to be.
