Your in-tank fuel pumps love you. I do pretty much the same.I say this a a compulsive topper-off who almost never runs the tank below half.
Scott
Doesn't make a bit of difference. If the pump is not submerged in gasoline then it isn't pumping and the engine is not running. Pump will only run 15-30 seconds if the engine is not running in a modern automobile. Turn on your ignition without starting and listen carefully.Your in-tank fuel pumps love you. I do pretty much the same.
For once, they sound right, wouldn't they......
Then ambulance chasers got the idea that a fuel pump still running after an accident was a fire hazard. ...
I'm not talking about the pump running dry, it's when the pump is not fully submerged in fuel. Being submerged in fuel keeps it cool.Doesn't make a bit of difference. If the pump is not submerged in gasoline then it isn't pumping and the engine is not running. Pump will only run 15-30 seconds if the engine is not running in a modern automobile. Turn on your ignition without starting and listen carefully.
When in-tank electric gas pumps first appeared Detroit was too cheap to put a cutoff safety on them. Pump would run any time the ignition key was on, even when idiot driver keeps trying to start a car with empty gas tank.
Then ambulance chasers got the idea that a fuel pump still running after an accident was a fire hazard. Manufacturers quickly added the non-running safety cutoff.
Yeah.............but you have to be kidding if you think ~1/4 tank won't run cool enough. Hitting a gas station every 1/2 tank solves zero. Waste of resources, mainly time.I'm not talking about the pump running dry, it's when the pump is not fully submerged in fuel. Being submerged in fuel keeps it cool.
Scott
Absolutely. I don't refuel at 1/2 a tank unless I'm driving to a remote, high cost area, something like Death Valley. I'll tank up somewhere on my way in so I can make a round trip out of the area without having to refuel while there. 1/4 tank? I usually refuel. 1/8 tank? Always.Yeah.............but you have to be kidding if you think ~1/4 tank won't run cool enough. Hitting a gas station every 1/2 tank solves zero. Waste of resources, mainly time.
Yep. Always filled at 1/4 tank on my 4Runner with its submerged pump, and the original pump was still going strong at 280,000 when I gave the truck away.I'm not talking about the pump running dry, it's when the pump is not fully submerged in fuel. Being submerged in fuel keeps it cool.
Scott
The only fuel pumps I've ever had to replace were in my wife's cars. She notoriously would run them as low as possible. Buying her an EV has saved me a bunch of money and she never forgets to charge at home. The easiest fix ever for those that love to get every last drop out of a tank before fueling up again.We routinely run our tanks to E and not had a problem with fuel pumps. My VW did lose a fuel pump--but it was a known failure mode, and it still made 250k before dying. That car also had a fuel cooler so it was not cool fuel in the tank on long trips. Most of our cars are owned to 200k as a min.
The 60's FWD Rivs, Toronados and Eldos were gorgeous. Classics! A couple of the Riveria years had the rolling speedo. I remember riding in one and couldn't keep my eyes off it.I had a 69 Buick Riviera
Pump is fully submerged in fuel when there is enough fuel to keep the engine running.I'm not talking about the pump running dry, it's when the pump is not fully submerged in fuel. Being submerged in fuel keeps it cool.
Scott
That's not accurate, at least in a lot of older vehicles. The pump would be somewhere down from the top of the tank with a foot valve assembly of sorts with a sock on it that descended into a baffled area in the bottom of the tank. The pump would not be submerged at about the 1/2 tank mark, maybe a bit lower.Pump is fully submerged in fuel when there is enough fuel to keep the engine running.
On properly designed ones yes. GM trucks in the 90's had pumps that would get loud and fail and this issue was exasperated by regularly running a low fuel level, as the body of the pump was cooled by the fuel.And if you have studied a submerged fuel pump you would know only the fuel inside the pump serves to cool/lubricate the motor.
And it wasn't submerged because it wasn't in the fuel tank (I know you know this @JeffKeryk). I used to replace those lever driven fuel pumps (driven off the cam) periodically, just for the heck of it.I think the only fuel pump I ever replaced was on my '66 GTO 389. It wasn't submerged but it was leaking. And Pontiac torque monsters are thirsty!
They'd sound like a baritone cicada, buzzing away. I had several friends that experienced it (multiple times), I remember the mechanics always recommending to keep at least 1/2 a tank in it, as running them low regularly seemed to increase the failure rate.Despite having owned a bunch of 90s GM trucks I never have had to replace a fuel pump on any vehicle in my life.
I'm still looking for the oil drain plug and Fram 8a, or whatever. I do check the oil level regularly though.Despite having owned a bunch of 90s GM trucks I never have had to replace a fuel pump on any vehicle in my life.
I was curious and just gave AutoZone a call to see how much fuel pumps were for our cars. Apparently neither a 2025 Model 3 or a 2025 Equinox EV have fuel pumps. Who would have thought! I can sleep well at night now.
No I didn’t actually call AutoZone and ask that, don’t worry.
