Another aritcle on Synthetics/Esters
NJ
SYNTHETICS IN THE USA. @1996 rewrite ~2000©
In the USA there are a few different types of synthetic base stocks used in engine oils. We will just touch on two in this technical / sales paper.
The word Synthetic is confusing; it describes a process, not a material. For example, White sand is synthesized into glass, but glass is never called "synthetic sand". Most people think that all synthetic oils are made of the same base, This is wrong! For most of the USA, there are mainly two types of synthetic oils (or as we like to say, synthetics are designer oils).
The most common is a PAO, short for poly-alpha-olefine, or easier to understand, it is synthesized petroleum oil. It is refined in a special process, or in simple words "synthesized". It still starts out by being pumped out of the ground. PAO’s are better than regular petroleum oil for handling heat, oxidation, low temperature startups and higher film strength. Drawback: PAO and petroleum are dynamic types of oil, you have to build up oil pressure and have rotation before a film is produced. Better said, you have to hydroplane the engine parts like you hydroplane a car in the rain, to create a film (or in the case of water-skiing, you have to build speed for the skier to get up and plane on the water). PAO’s are not very expensive because they are made from crude oil and produced in large quantities. You can usually tell when PAO’s are the main ingredient used as the cost of the 100% synthetic oil is less than $7.00 per quart.
The other main type of synthetics are synthetic esters, (diester, polyolesters, polyesters and complex esters). Motul® uses esters in its products. Esters are mostly made of vegetables, minerals, and animal fatty acids. Motul’s® esters contain a lot of coconut derivatives. Esters are much more expensive because the ingredients all have to be collected from natural resources and synthesized (a very expensive process) in smaller quantities. Esters have all the advantages of a PAO but more of them. Esters can handle heat better than PAO’s and when burned, esters leave far less coking deposits. Esters are static types of oils and are attracted to metal parts with an electro-chemical bond. This means no more metal to metal start ups. This also means that a film is there before the oil pressure light goes out preventing premature wear of high-stressed parts like cam lobes. The film created is up to 5 times stronger then petroleum oil.
The number one reason to run an ester synthetic oil is bond. The electro-chemical bond is made because the ester molecule is polar. Sort of like a refrigerator magnet. It is attracted to metal and sticks.The PAO molecules are neutral and act like a piece of plastic placed on the fridge. They just fall off. All commercial jet plane flying, use an ester synthetic of some type and not a PAO. You need to run an ester of some sort for maximum protection.
There are some companies calling level 3 petroleum base stocks synthetic. This oil is a good Petro oil. But it is not what we call a synthetic. The end result is that some oils are labeled incorrectly and are very inexpensive.
Let’s explain why handling higher running temps is important.With petroleum oils there is a much better risk of failure from volatility problems than with synthetics. Why?
Have you ever burned butter while cooking? Yes, everybody has burned butter! The running temp or maximum temp is low. When butter reaches its maximum running temp it starts to evaporate (volatility) then it carbonizes and then it sticks to the metal pan. Now compare butter to vegetable oil in which you deep fry french fries. The only way to heat vegetable oil so hot as to make it carbonize, you would almost need a direct flame.
Petroleum oil is like butter as far as handling heat! Synthetics are like vegetable oil - synthetics won’t burn up and stick to your engine parts or go out the breather as fast as petroleum oils will. Remember esthers leave almost no deposits if they do burn this is the second reason to run a synthetic oil. Because you’re not supposed to have extreme heat problems everyday.
Basic tech points: motorcycle oils vs. car oils
Most modern day motorcycles have one filler hole for the engine oil. The oil must do three jobs.
Lube the engine.
Lube the transmission.
Lube the clutch.
A car with a manual 5 speed transmission has three different compartments, using two different oils to do the same job:
Motorcycles, especially air or oil cooled designs need lubricants that can handle higher running temps to increase viscosity retention, while reducing consumption and oil film breakdown. Especially since the capacity of oil is only 1 to 4 quarts.
Motorcycles use a constant mesh gearbox that shares the engine oil. Because of this, Motul® adds more medium extreme pressure (EP) additives such as zinc and a strong EP additive, called a sulfurized ester to handle the shear / meshing of the constant mesh gearbox.
EP additives come into play at the instant a medium extreme pressure’ is applied and high temperatures are created. Zinc lays down a barrier that prevents metal to metal contact and the sulfurized ester produces a sacrificial film that is destroyed during very strong extreme pressures as it prevents seizing. EP additives are generally corrosive especially those used in car gearboxes. We use this ester because it is far less corrosive and more environmentally safe than others that can do the job. This is what those TV advertised products forget to tell you when you see them test a ball bearing under 100,000 pounds of pressure.
To explain it easier, let’s take a sandwich wrapped in plastic wrap (the EP additive would be the plastic wrap). If you were to squeeze the sandwich you would contact the plastic wrap with your fingers (your fingers representing the gears) and the sandwich would squish, however, your fingers never actually made contact with the sandwich.
Motorcycles need a balanced friction modifier package. So that the wet clutch functions properly, ring seal stays strong and roller bearings roll and do not slide and flatten.
Super slick oils (energy conserving II type) are not recommended for today’s high powered motorcycles. Clutches will not engage correctly and will take longer to engage or slip and chatter when placed under heavy stress. (i.e. racing, passenger, trailer, uphill) also the plates will glaze up from burning/slipping.
Too much friction reduction will hurt your engine. Rings will skate instead of seal, reducing compression and performance.
Roller bearings will not roll, but slide causing flattened pins.
NOTE: The sulfurized ester is a part of this friction reduction package due to it’s ability to stick to engine parts (non- ferrous metals)
Motorcycles need strong anti-acid known as a base (TBN: total base number).
The steam that you see coming out of your tail pipe in the morning is condensation, which is a natural by-product of combustion in an engine. This condensation, which is acidic water, passes by the rings under compression into the crankcase and mixes with the sulfur, sulfuric acid is created. Anti-acid (base) neutralizes the acid before it can cause any damage.
Motorcycles need strong antl-foam additives to handle the design of the motor.
Motorcycles usually run at higher rpm’s than cars which aerates the oil more.
Motorcycles have more internal moving parts in the crankcase than cars do, foaming up the oil (engine-clutch-clutch basket, gears, shift drum, shift forks).
Motorcycles lean into turns, which may cause the clutch basket and gears to dip into the oil which causes excessive foam similar to whisking egg whites in a high speed mixer.
We must pop the bubble before it causes damage! Why?
Foam is air, air is a better insulator then a transmitter of heat. It does not transmit heat from hot metal parts to the oil very well or vice versa.
Problems – oil pumps do not pump air.
Oil pressure can drop!
TEMP’S can RISE due to inefficient heat exchange
Motorcycles need strong dispersants to suspend the clutch material and combustion by-products that are created and rubbed off during normal operations.
When you are waiting at a traffic light in gear or taking off from one. Where does the clutch material go? Right into the oil!!! We want the material to stay in small pieces and stay mixed in the oil, so that the oil filter can do it’s job. Otherwise the material will drop to the pan and collect in corners waiting for the day that you hit a wild bump and bounce back into circulation causing a clogged artery to anything it can. Just like a heart attack.
Motorcycles need a strong detergent, Why?
Because of more heat generation (more horsepower per cc than cars) trying to fry the oil onto the engine parts, and added dirt being dropped into the oil from the clutch and by-products from combustion.
Synthetics (now) can (if you cannot find your brand) be mixed with most high quality mineral, PAG or ester synthetic oils without major problems. Try to stay close to the viscosity range of the first oil. (I.e. 10w40 mixed with 10w40). We recommend an oil change when you get home from the "long" trip that consumed the oil, since the oil additive and base from the old oil is now not balanced.
These are some of the main issues that Motul® looks at when designing a motorcycle oil. As discussed earlier, synthetics can handle much higher running temperatures than conventional petroleum oils and can withstand more stress. Many people ask, so what! I don’t push my cycle that hard and I change oil every 1000 miles! I don’t need a $5.95 to $10.00 quart of oil in my bike. This is WRONG thinking ! The question we have for you folks is a simple one? Why do you wear a helmet? Gloves, boots, jacket and why do you buy insurance? In case of an accident! Right!! If within the first fifty (50) miles after an oil change, a rock hits your radiator or the thermostat sticks, the water pump stops pumping or whatever causes a major heat problem in your cooling system, what would you rather have in your engine? A mineral oil that acts like butter, that burns up and evaporates very quickly and also carbonizes OR an oil that can handle high running temps like synthetics (3250f to 3670f). High quality oils are insurance not only maintenance. Same is true about brake fluids and gear oils.
JASO MA:
There are some new ratings from JASO, which is a group of engineers that decide what standards will be placed in effect to ensure proper performance for motorcycles. Motul has already several oils meeting these standards. The focus is on friction and clutches, EP and cleanliness.
Source: http://www.scooterhelp.com/genmaintain/crankcase.oil.html
It's my understanding that this polar effect film also keeps the EP AW additive from staying in place. Sort of gets squished away before it's done doin it's job. Also that the polar film is no subtitute for the additives at doing this job.
Higher wear can be observed in areas where metal to metal can occur, an "extreme" not mentioned above. The solution is a extra heavy dose of extra additive in the ester oil betting that enough will be there when the time requires it. Something that PAO or mineral wouldn't really require.
NO problem, add more additive? but in light of reduced additive levels mandated by new specs, can an API-SM glf-4 ester based oil give the same AW EP protection without polluting the cat with additive or being an under achiever in AW EP? I know, throw more moly in it, LOL.
wiley, good point, one that has been brought up by XOM/Shell. BTW, all the so called ester based oils like RL and Motul are 65% PAO. RL is not 100% ester based.
There is more WRONG in that scooter posting than what is correct.
bruce
in 6 weeks or so i will be testing Motul 5100 in the infamous Mix Master of DOOM!
then we'll see how it stacks up compared to the other 21 used oil analysis i've done.
so far, MMoD 16, oil 4. (1 used oil analysis is in the mail now).
I don't know the definition of "feedstock" in this case, but the carbon in PAO starts out as fossil fuel. PAO is made from ethylene and ethylene is made from steam cracked light fractions or catalytically cracked heavier fractions.
Wow. For someone who isn't "all that" into the actual chemistry, it would make me scared to use M1 anymore and need to quickly change the oil or my engine will be absolutley self destruct. So, PAO's aren't that bad or what? I'm really confused on all this now more than I ever was. Geeeeeze, wouldn't you just know it, right when I get comfortable with my knowelege on synthetics, this comes along and brain screws me again. Dang you bobistheoilguy!!!!!!
Schmoe, use common sense - formulated mineral oils work just fine in automotive engines as proven by years of sucessful use. That makes PAOs overkill for normal people, and esters are double overkill. Only if you are doing something at or beyond the limits of the operating envelope, will you gain the benefits of the overkill. A very small percentage of users will need the actual benefits, most will just be spending money for peace of mind.
Who said money can't buy happiness? ......
Tell my ex that...................it's just there is so much information out there that once you think you got a pretty good hold on it, something comes around and challenges your own personal theories. Such is the case. I didn't like the part that PAO's will not leave a protective barrier and is not attracted to metal where as ester are polar and will. But akin to what your saying, is it absolutely necessary? Probably not, but when in cold weather cranking, that would give one a warm fuzzy, if you will.
Formulated PAOs will have ant-wear additives that go to the metal surface for start-up protection. Esters actually compete with the anti-wear additives and can make the formulation of an ester lubricant more of a challenge.
I work with refrigeration lubricants that use POE bases. We use TCP to provide some anti-wear and ferrous metal deactivation, but the activity of the TCP in POE is much less than in mineral oils because it has to compete with the polarity of the POE basestock.
Another not well discussed item is the fact that POEs with their inherent high viscosity index have a counterbalancing feature of having a low pressure viscosity index. When a low VI mineral oil is mechanically sqeezed between two low velocity metal surfaces the lubricant will increase viscosity and be very hard to push out from between the two surfaces. A high VI base will not thicken up as much under applied mechanical pressure and is more easily sqeezed out. Piston rings at top dead center have low velocity and may be under a lot of mechanical load - POEs will not hang in there as well as a mineral oil. When the rings are moving both lubricants will go back to hydrodynamic lubrication.
In refrigeration, POEs are a disaster in rotary vane compressors. The vane tips sqeeze the POE out from under them and cause rapid excessive wear. Mineral oils work much better. Anti-wear additives in POEs just don't do the job in that application, and it requires hardening the vane tip with nitride metal treatments to get the vane tip to survivie.
Esters like POEs are very good in some applications, but may not be the best choice in others. They do make interesting materials to formulate with, but are somewhat costly. If you need the benefits of esters, then you have no problem with the cost like in jet turbine engines and air / refrigeration compressors.
Bruce381 nailed this article correctly - there are major problems with its technical accuracy and claims. The person who wrote the article above seems well versed in the marketing hype.
This has been mentioned before, as XOM and Shell have stated. I know Mobil said their AN's are less polar then esters and more ideal in that aspect. Oils like Redline/Fuchs etc. do use PAO's as well, just in smaller amounts from my understanding.
Detergent additives in oil also compete for surface with the AW EP additives, that's why there needs to be a balance in the formulation. Something to think about when you start pouring those bottles of supplements in that look so stout on the add's? What happens to the balance?
"We use TCP to provide"
holy smoke we stopped using TCP years ago was/is there not a cancer/skin/eyeball burning thing with TCP?
"When a low VI mineral oil is mechanically sqeezed between two low velocity metal surfaces the lubricant will increase viscosity and be very hard to push"
good note most people do not know that low VI nap oils will form thick films upon high presure and work very well in EHL regimes but the oxidation sucks but not a problem with in a sealed AC unit.
bruce
The ortho isomer of TCP is the problem with toxicity. All commercial TCP these days is ortho isomer free. I understand almost all jet turbine POE lubricants use TCP, as without it the POE will be chewed up quickly by the iron at high temperatures.
