I've been running a test on various motor oils in a 1999 Honda Accord that sees a lot of miles. I was curious if one oil was really better than another.
I tested each oil for right at 10,000 miles using the same oil filter. The drive was the same with about a 50/50 split of city and highway for each sample tested.
The oils tested were:
Castrol GTX 10W30
Castrol Syntec 5W30
Penzoil Platinum 5W30
And now the Mobil 1 5W30
I would run each oil for 10K miles, and run another oil change with the same oil for 10K miles before taking the sample, so this test was conducted over a couple of years and roughly 80,000 miles.
What I found is that all the synthetics were pretty close to each other in performance, but the Penzoil Platinum did seem to edge out the rest by a small margin. For the price it can't be beat, but I'm not telling you guys anything you don't already know.
This latest analysis is from the Mobil 1 5W30.
Vehicle: 1999 Honda Accord 2.3L 4cyl Automatic Trans
Miles on Engine: 174,910
Oil: Mobil1 5W30
Filter: Purolator Pure One
Miles on Oil: 9,604
Time on Oil: 4 months 27 days (all samples have nearly 5 months of time on them)
Black Stone was the lab used for all samples.
Comments:
It's fine that you didn't change the filter this time. We use the insolubles test to determine the effectiveness of oil filtration, and your 0.3% reading is great. We've found that most people don't really need to change the filter every time they change the oil. Wear looks good too. Aluminum and iron have increased slightly over last sample, though lead improved. Overall we'd say this oil is working just fine for you and if you like it, stick with it. You could even push it a little longer if you wanted. The TBN read 3.9, so try 11,000
miles next time. Check back.
Code:
ELEMENTS IN PARTS PER MILLION
Aluminum: 4
Chromium: 1
Iron: 11
Copper: 4
Lead: 10
Tin: 0
Molybdenum: 83
Nickel: 1
Manganese: 0
Silver: 0
Titanium: 0
Potassium: 4
Boron: 105
Silicon: 14
Sodium: 7
Calcium: 3275
Magnesium: 16
Phosphorus: 873
Zinc: 932
Barium: 0
PROPERTIES:
SUS Viscosity @210*F: 66.2
cSt Viscosity @ 100*C: 11.93
Flashpoint in °F: 365
Fuel %: TR
Antifreeze %: 0.0
Water %: 0.0
Insolubles %: 0.3
TBN: 3.9
So I also have a supercharged Toyota 4Runner. It doesn't get driven nearly as much, so I only change the oil and filter in it once a year. This is usually about 2000 to 2500 miles of use on the oil. I tested Castrol GTX 10W30 as well as Penzoil Platinum 5W30 in that vehicle. The Penzoil Platinum was head and shoulders above reducing lead to the same magnitude as it did in the Honda.
Castrol GTX 10W30
Castrol Syntec 5W30
Oil: Mobil1 5W30
Miles on Oil: 9,604
Comments:
Code:
Aluminum: 4
Chromium: 1
Iron: 11
Copper: 4
Lead: 10
Tin: 0
Molybdenum: 83
Nickel: 1
Manganese: 0
Silver: 0
Titanium: 0
Potassium: 4
Boron: 105
Silicon: 14
Sodium: 7
Calcium: 3275
Magnesium: 16
Phosphorus: 873
Zinc: 932
Barium: 0
PROPERTIES:
Fuel %: TR
Antifreeze %: 0.0
Water %: 0.0
Insolubles %: 0.3
TBN: 3.9
