Originally Posted By: LT4 Vette
Have you considered trading it in for another car ?
Have you considered stuffing a nice Buick turbo in it?
Two of my evil fantasies, just to twist people's noses the wrong way:
1) stuff a turbocharged slant-six into a '63 split-window Corvette to get back at all the hot-rod builders that put a small-block Chevy in *everything*,
2) Stuff anything American (even a small-block Chevy) into a Honda or Toyota to improve its reliability.
Just kidding. Well about #1 anyway. And mostly #2. Mostly.
Seriously, I assume the TL probably has a high (over 10:1) static compression ratio. No matter how advanced the combustion chamber design and fuel/spark management, when the inlet temperature reaches a certain point you're GOING to get some ping without high-octane fuel. It sounds like yours may also have a carbon build-up problem, lack of enough EGR flow (EGR is actually good for reducing ping because it slows flame propagation), or some other small problem that's making it harder for the engine management system to cope. The higher the static CR, the more sensitive the engine is to all the other things that go on to limit ping. You could even have a coolant flow problem where part of the engine is running too hot by a few degrees, and that wouldn't necessarily show on the gauge. Little stuff that goes unnoticed on a less stressed engine can be really hard to track down. Good luck, and if you find a clear-cut cause, I'd like to know what it was just for curiosity's sake.
