Originally Posted By: Bigdaddyeasy
I dunno why people all over the web love to compare m1 to Amsoil. Its really over complimenting m1. Their not in the same league in my opinion. M1 is a typical synthetic. M1 ep is built for modest extended oci. Amsoil is built for greatly extending your oci. If your only going 10 to 15 k with amsoil your throwing your money away. If amsoil cannot extend beyond that in your application, you need to just follow your reccomended oci and use the recommended oil and see if that's reasonabl for your situation. Amsoil isnt right for every situation.
AMSOIL specifically states, as per the verbiage I quoted earlier, that 15K is the limit for any application classified as "severe service", which was also defined in what I quoted.
Any extended drain programme should consist of regular UOA's to establish the acceptable limits for the machinery and lubricant. Arbitrarily running a lubricant several times the OEM interval because the lubricant is rated for "up to" that number is foolish as every application is different and places different demands on the oil.
M1 EP and AMSOIL SS are both extended drain oils and subsequently are both comparable. If the AMSOIL product is capable of longer drains than the Mobil product in a given application, then it makes more sense to use that product. And this assumes you are operating within the limits set by both companies, which indicates a maximum OCI of one year, and, as noted in AMSOIL's verbiage, a maximum of 700 engine hours.
