2003 Pontiac Montana 3.4l V6
Amsoil dual remote filtration
Amsoil TS foam air filter
99% hiway miles
time on oil: 2 months
Current odometer: 124,000km
Make up oil: 0.5L
Amsoil S2K 0w30 on the left, M1 SS 5w30 on the right. Both were 20,000km(12k miles).
Tin 1 1
Lead 2 2
Copper 18 14
Aluminum 5 0
Silicon 19 12
Iron 16 21
Chromium 0.5 0.7
Silver 0 0
Zinc 1150 1050
Magnesium 849 84
Nickel 0 0
Barium 0 0
Sodium 11 9
Calcium 2000+ 2000+
Vanadium 0 0
Phosphorus 1050 886
Molybdenum 2 82
Boron 25 73
Manganese 184 159
PHYSICAL PROPERTIES
Viscosity 14.57 11.55
Water 0 0
Solids Glycol No No
Fuel Dilution No No
TBN 9.40 9.70
Oxidation 0.19 11.52
Nitro Compounds 0.00 0.00
Organic Nitrates 14.48 15.62
Well this is almost a toss up. Each oil performs better in certain categories with M1 getting the edge for maintaining it's viscosity better. It thickened by 1cst according to my VOA numbers. If it can maintain that rate, it'll make 40,000km and still be in grade! I havn't changed the SDF-15 filter as Amsoil recommends. Frankly I see no need to since it's only been on there 2 months. I leave it on for as long as the oil stays in and see what happens. I'll probably check in again around 35K km and decide from there what I want to do.
99% hiway miles
Make up oil: 0.5L
Tin 1 1
Lead 2 2
Copper 18 14
Aluminum 5 0
Silicon 19 12
Iron 16 21
Chromium 0.5 0.7
Silver 0 0
Zinc 1150 1050
Magnesium 849 84
Nickel 0 0
Barium 0 0
Sodium 11 9
Calcium 2000+ 2000+
Vanadium 0 0
Phosphorus 1050 886
Molybdenum 2 82
Boron 25 73
Manganese 184 159
PHYSICAL PROPERTIES
Water 0 0
Solids Glycol No No
Fuel Dilution No No
TBN 9.40 9.70
