Compared to the prior interval, this one was about 4 months shorter, slightly more cold weather starts, and more loaded miles.
Comparing to AMSOil: no shear, stayed in-grade for a 40wt. TBN held up better, I suspect owing to a higher starting level. No make-up oil. But, perhaps all for naught since there was a notable increase in iron. Then again, while notable, is it significant as regards engine life? That's what ultimately matters.
According to Blackstone's written comment to the prior UOA, the universal average is 7600 mi. I rather suspect M1 is also the universal average oil -- look at the Moly, plus we know it's the factory fill -- so, at 50% more miles, as to be expected, I'm at 50% more wear.
I'll say, at 1/2 the cost of AMSOil, better TBN, and no make-up oil req'd, my inclination is to stay with M1. What's not to like?
Without further ado:
Code:
ALLAN: Wear went up just a little. It's hard to pinpoint exactly why that might
be. We see way more changes to wear because of operational differences than a
change in brand. But if you know you're pretty much using the engine the same
now as you were last year, and if you switch back to Amsoil (again, with the
same type of operation going on) and iron drops? Then we'd say yep, Amsoil is
the reason for the improvement. The TBN read stronger here than last time, and
the viscosity is correct for 0W/40 oil. No fuel found. Nice engine, regardless
of the oil!
Fill M1 AMSOil Univ Avg
0W40 5W40
Mid-SAPS
Miles 11,700 11,800 7,400
Months 12 16
Make Up Oil 0 qt 0.5 qt
ALUMINUM 5 5 4
CHROMIUM 1 1 1
IRON 46 32 28
COPPER 13 13 7
LEAD 1 2 1
TIN 0 0 1
MOLYBDENUM 80 16 74
NICKEL 0 0 1
MANGANESE 1 1 3
SILVER 1 0 0
TITANIUM 0 0 0
POTASSIUM 5 0 3
BORON 122 53 98
SILICON 10 11 9
SODIUM 7 7 18
CALCIUM 2832 1634 2257
MAGNESIUM 28 18 62
PHOSPHORUS 869 702 840
ZINC 1054 861 969
BARIUM 0 0 0
Values Should Be*
SUS @210°F 72.8 63.0 65-78
cSt @100°C 12.7 11.06 11.6-15.3
Flashpt in °F 400 405 >375
Fuel %
Antifreeze % 0.0 0.0 0.0
Water % 0.0 0.0
Insolubles % 0.3 0.2
TBN 3.6 1.9 >1.0
FWIW, my prior UOA.
Code:
of the oil!
0W40 5W40
Mid-SAPS
Months 12 16
ALUMINUM 5 5 4
CHROMIUM 1 1 1
IRON 46 32 28
COPPER 13 13 7
LEAD 1 2 1
TIN 0 0 1
MOLYBDENUM 80 16 74
NICKEL 0 0 1
MANGANESE 1 1 3
SILVER 1 0 0
TITANIUM 0 0 0
POTASSIUM 5 0 3
BORON 122 53 98
SILICON 10 11 9
SODIUM 7 7 18
MAGNESIUM 28 18 62
ZINC 1054 861 969
BARIUM 0 0 0
Values Should Be*
Fuel %
Water % 0.0 0.0
TBN 3.6 1.9 >1.0
FWIW, my prior UOA.
