Tempest,
Mayby I can help with where to use ATD and ATF. ATD is designed to be used in heavy-duty Allison transmissions. A couple of their requirements are that the fluid is full Synthetic, does not have a viscosity modifier and also meets the viscosity requirements. After making this fluid it was determined that it could also be recommended for similar specifications such as the long drain synthetic requirements for Voith and ZF. The formulation and viscosity also allow us to recommend it for Mercon and Dexron III. It is not meant to be and cannot be recommended for the many specifications that our ATF was designed to be used for. Although our ATF could be used in these heavy duty applications and provide good performance, ATD was designed specifically for those heavy duty applicatons and at a cost much less than the Castrol TranSynd. After Field testing in B500 Allison transmissions AMSOIL ATD and Castrol TranSynd had vertually the same viscosity as the start of the test and if you didn't know which sample was which, you could not tell any difference by the wear PPM's.
For a full listing of what specifications we recommend ATF and ATD for visit our web site.
I hope I've added some information that helps everyone understand.
Kevin
Kevin
