So I have a performance transmission that requires Mercon V.It can create some heat when really beat on, but around 190 is the max temp Ive seen. I plan on doing a pan drain and refill every year to year and a half using standard Mercon V fluid ( Ford approved fluid only ). What Im wondering is if its worth the cost to use Amsoil Torque-Drive over the standard Mercon V? Im sure its a better fluid than standard V and has better characteristics all over ( from heat to cold fluid flow )... If I were to run the Torque-Drive fluid Id drain every 2-3 years as it ( id assume here ) would hold up way better.
What do you all think?
