Amsoil SVG 75w85 in 2019 Edge ST PTU?
The <2017 Ford Edge Sport PTU calls for 75w140
The >2019 Ford Edge ST PTU calls for 75w85.
I've changed my fluid once at around 35k with the Ford 75w85 fluid but am looking to try the Amsoil SVG if it could help keep PTU temps down? Car is a little over 40k miles now and with the factory warranty out I'd like to do what I can, at least from a maintenance and fluid standpoint, to keep everything working as it should for as long as it can.
Should I stick with what the service manual calls for first, which is 75w85 (and not go to a 90w or higher?) And when I swap it over should I drive it a few miles and flush it again so its closer to 1 fluid type? My PTU doesn't have a drain plug so I get to suction it out or pop the PTU cooler off to drain, its much less than ideal :)
Perhaps some of these may help:
The thing is, the FSM calls for 75w140 in those applications. In the 2019 ST it calls for 75w85. Should I stick with what it calls, has anyone tried a 75w90 or higher?
This thread was timely.
I changed the gear lube in the transfer case of my 2006 Suzuki GV today. It was very easy, 1.3 qt. Mobil 1 75W-90, drain and fill. It replaced some Amsoil I changed ~50K ago. Meanwhile my 2018 Edge with the 3.5 and its notorious PTU was loitering in the garage. It was changed @45K at the local Ford dealer with their recommended Motorcraft lube. Car now with 56K. Since I don't have a lift and the transfer case exchange is more vexing than college calculus, the dealer option is all their is. Every 30K seems excessive but a new PTU is very $$.
I've decided given this otherwise excellent vehicle is blighted with a suicidal internal chain driven water pump and a PTU baked daily like a slab of Memphis ribs, it will be traded sooner than later. There is no earthly excuse for this engineering malfeasance.
I said before, this is my final Ford.
Thinner oils will transfer heat more quickly. If FSM says 75w85, I wouldn’t go thicker if you’re interested in keeping temps as low as possible. 75w140 will raise temps relative to 75w85.
SVG is an excellent fluid, as is another 3-letter moniker familiar to this board if you’re so inclined.
What did the oil look like when you changed it at 35k? Some owners have complained that since the PTU is so close to the exhaust system, the oil gets burnt and oxidized quickly.
A 75W85 offers little advantage over a 75W90 except for fleet mpg figures. It may run a fraction cooler, but most likely the difference cannot be measured without an accurate sensor.
If they changed the internal PTU design and repositioned the PTU to cope with the exhaust heat, then stay with the 75W85 if it was not burnt.
Had a 2015 - wrapped header tape around the exhaust pipe …
I don't think it looked terrible, but I don't pretend to know much. I attached some pics from when I changed it. It still looked a little amber I thought and was definitely not caked, gummy, tar-goo, etc. This PTU is coolant cooled (if 200* cooling is a thing idk), with no drain plug of course.
Since its coolant cooled, I'd stay with the 75W85 and change it every 35k since you have a system for changing it.
Sucks Ford has been saving a few beans with no drain plug. I was not aware that Ford was using coolant to moderate PTU temps.
That PTU fluid looks pretty good with the extra auxiliary cooler.
