JAG
Results are in for Mobil 1 Extended Performance 0w20 and Castrol 0W-40. The Mobil 1 was bought within the last year and the Castrol is from around 2010-2011.
Abbreviations: Mobil 1 and Castrol
Mobil 1 basically did a repeat performance of the last test. A quite large amount of varnish was scraped off from where Mobil 1 attempted to clean the varnish spot...it did NOT dissolve the varnish well. Castrol, in the other hand, behaved like AMSOIL Signature Series 5w20 did in the previous test: it dissolved the varnish so well that the straight razor did not scrape off any varnish. I am quite shocked and disappointed in Mobil 1 Extended Performance 0w20. I have only tested it and two other excellent oils in this way. Maybe the Mobil 1 cleaning ability is typical of modern oils sold today and oils that clean as well as AMSOIL Signature Series 5w20 and Castrol 0W-40 are in the small minority. Or maybe the not-so-good cleaning ability of this particular Mobil 1 is in the minority. Only way to know is test a lot of oils and I’m not going to do that but I will test some oils of particular interest to me or others here. Pics follow:
Plate after creation of varnish (from Mobil 1 Extended Performance 0w20...did not burn) and where each fresh oil was going to go.
After 24 hours of fresh Mobil 1 oil soaking and removal of oil with throttle body cleaner. No rubbing. Before scraping with straight razor.
Likewise for Castrol.
Mobil 1. After scraping half of the varnish deposit, stopped to photograph to show that the deposit literally comes off. You can see the scraping on the edge of the razor.
Mobil 1. All varnish scraped off. Got a rather large amount on the blade’s edge.
Castrol. No varnish was there in sufficient thickness to scrape off.
Entire plate. Pile of varnish that Mobil 1 could not dissolve is visible in the picture.
