Has anyone had a chance to use and evaluate Amsoils new Severe Gear? If so, what did you use it in and what do you think about it? Good? Bad? Indifferent?
The marketing sounds good, but I hate to be the first to try something. But...since both my Jeeps are about due for a change, I might give it a shot.quote:
Originally posted by Pablo:
It's really so new, in fact I haven't even smelled it yet.
It smells just like...actually it didn't have much of a smell at all.quote:
Did you pull the cover off and clean out the metal in the rear diff or just swap fluid?quote:
Originally posted by [email protected]:
I actually changed my front and rear (anti-slip) axle on my 02 Envoy with the new Amsoil Extreme Pressure Severe Gear lube. Before the oil change, I was having my rear axle "rumble" upon takeoff (the original fluid and anti slip additives were spent and my clutches were "angry" if you will).
I noticed the difference immediately. No more rumbles, vibrations, noises. Glad I came on here and read a different post about itSaved me alot of $$$ (the dealer wanted $300+ to change front and rear axle fluids!) I only paid $7.20 x 3qts=$21.60 total. I got it at "dealer price". Definately recommended.![]()
Was this in a manual transmission?quote:
Originally posted by par:
If it's similar(or better!) than the series 2000 Amsoil, then it should be perfect. Amsoil in Toyota trucks is the best and I've tried neary everything (RL, RL-50/50 mixed, RP, M1).
I am now trying 75-140w SVG in my rear differental,in which full synth (permanent oil as per Ford manual)was in it, but when I buy a new to me automobile I change all fliuds as PM measure. It works so far,but still under test.quote:
Well on my rear axle a sway bar is in the way. I just drained it (my plug is magnetic and had a fair amount of metal moosh on it) I let it drain for about 30 mins and then refilled. Same with the front.quote:
I have an '04 Avalanche and am looking for an alternative to the GM fluid.
Thanx
Bob W.
