Where are you seeing it for 1/3 the price?
https://www.amsoil.com/p/amsoil-severe-gear-75w-90-100-synthetic-gear-lube-svg/
https://www.walmart.com/ip/Mobil-1-Synthetic-Gear-Lubricant-LS-75W-90-1-Quart/110167556
It's $17.29, less than $2 more than the Mobil 1 at Walmart. Similar price for the Valvoline. And you get the easy fill packs.
If you're doing both diffs and a transfer case, then that's probably enough to order and get free shipping. Or you can order something else that you need, like some gasoline treatment or something. Their PEA gas treatment is pretty good, and I run one before I change the oil.
@Pablo has also said here that if the PC membership is a bridge too far for you, he can help you out with ordering with preferred pricing. For $1.43 a quart more, I think it's worth it.
Edit: I should also add that I've got Severe Gear in all my diffs and T-case in both cars now. No issues. They both run great. I also switched from Red Line MT-90 to AMSOIL's MTL, and it shifts noticeably better in cold conditions than the Red Line did. (Both shift similarly when warm.) So I'm a believer in their gear oils. And the experience online here and elsewhere seems universally positive.
