Is it the TO brg or the input shaft brg that's noisy? The TO brg would be noisy mainly when clutch pedal is pushed, Input shaft brg inside the transmission will be noisy in every gear except direct drive gear where input speed equals output speed. On my truck this is fourth gear. Bad or worn/disintegrated pilot brg or bushing will cause the input shaft brg to go bad sooner. I had a bad input shaft brg, and needed better protection to keep the unit together until I had time to repair it, so I dumped in 3 quarts of 75W-140 Severe Gear and it really smoothed out the rattles and noise somewhat for about a year, and kept the unit from self-destructing. I had to take care shifting while cold and actually had to shift faster to the next gear when cold, since the thicker oil slowed the gears down more quickly between changes. After warming up things started to normalize and smooth out. I really liked to feel of the thicker oil in that worn trans. Now that it has been overhauled with new syncros and brg kit, (and input and output shafts had to be replaced,) I am using the MTG and is working perfectly. This was on my 90 Ford Ranger.
