dnewton3
Staff member
I do see your point now that you've expounded on it.
However, I still take exception ...
How is Amsoil "better product" in this application? Where's the testing data to show that it outperforms Mobil 1? Or, for that matter, a slew of the other lubes on the QPL ? You say there's a "consensus", but I disagree. (There's rarely ever a consensus on BITOG ...)
I agree with you in that a "standard" should be set. In this case, it's the SAEs J2360 protocol for gear lube performance testing. So as long as a lube is picked from that list, then COST can be the deciding factor. There are some really expensive lubes on that list, but there are also some really good deals on that list as well.
No where is Amsoil on that list. However they may be using one of the qualified packages from Afton, Lubrizol or another source; we don't know. And, though Mobil is on the list as a brand, it's their heavy-duty lube products which are qualified (both conventional and synthetics); the "normal" Mobil 1 gear oil is NOT on the approved list. The Mobil Devlac 1 is on the list; at least that's one of the choices he's considering.
One of the easiest to attain at a reasonable price is the Valvoline Synpower products. Pretty much can find them anywhere and for less money than Mobil or Amsoil. I'm not saying that Amsoil and Mobil are not worthy of considering; they certainly are. But the normal Mobil 1 and the Amsoil aren't even on the QPL list, whereas many other products are.
If you agree that using a "standard" is the right first step, then why are you advocating for a product that isn't even on the SAE performance qualified product list ?????????????
Again, when two products are qualified to the same standard, and one costs less, why would you buy the more expensive one?
In this application, the Toyota diffs are very reliable. They could last hundreds of thousands of miles even on ST lubes, given a reasonable OCI plan. And that OCI plan hasn't even been discussed as part of the overall topic, and yet it plays into the conversation as well.
Further, usage comes into play here. Is the 4R going to be a road queen and rarely if ever go serious off roading? If the axles get submerged on a regular basis, it's by far more important to change the lubes after submersion, rather than worry about what is the "best" lube (in the bottle). Frequent off-roading with submersion would be FAR, FAR "better" served by drain/fill cycles frequently, even if you used ST. Clean inexpensive fluid is much more desirable than a contamination "premium" fluid.
In summary:
- the Amsoil is not on the QPL
- the Delvac 1 is on the list, but expensive
- Synpower is on the exact same approved list, but costs the least of the three
The data is there for everyone to see, as long as they take off their rose-colored biased glasses.
In summary:
