1992 Ford Aerostar 3.0 automatic.
112,000 miles on engine.
Oil Use Interval: 21,000 miles (mainly highway – less than 1 year)
Oil: Amsoil Series 2000 0W30 (SL)
Make-up oil added: 3.5 qts.
Blackstone's comments:
We think 21,000 miles on an oil is too long for this engine to handle. Please note the high amounts of chrome (rings), iron (steel parts sharing oil) and lead (bearings) that have left a lot of abrasive metals roaming inside the engine. Universal averages for typical wear are based on a 4,760 miles of oil use and a couple of short oil change intervals would clean up the V-6 in your Aerostar. Sodium was found and might be coolant seeping into the oil or is an additive in the oil. TBN was 2.1 (little active additive left – 1.0 is too low), Viscosity was in the 20W50 range. Check back to monitor.
Element This analysis Universal average
Aluminium...... 6 3
Chromium...... 6 1
Iron ............48 15
Copper..........8 5
Lead.............14 5
Tin ...............3 1
Molybdenum...10 38
Nickel............1 0
Manganese.....1 0
Silver.............0 0
Titanium.........0 0
Potassium.......2 1
Boron............22 48
Silicon............27 16
Sodium.........25 10
Calcium.........2448 2024
Magnesium.....795 223
Phosphorus.....858 759
Zinc..............1022 900
Barium............0 1
Values should be Tested values were
SUS viscosity @ 210F... 56-64 89.9
Flashpoint F ............... > 365 395
Fuel %....................... < 2.0 < 0.5
Antifreeze %............... 0 ?
Water %.................... 0.0 0.0
Insolubles %................ < 0.6 0.4
What would the UOA have been like if no make-up oil were needed and I had used the oil for the recommended 35,000 miles?
This engine has used Amsoil Series 2000 0W30 exclusively for the last 100,000 miles. I'm going to try Mobil 1 EP 5w30 next time.
I am currently doing an Auto-Rx treatment.
Note that I am using a K&N oiled air filter but I noticed the filter housing box might have been letting in some unfiltered air.
Note to Moderator: A blank form on which posters can input their figures would be helpful.
Jan Richter
Aluminium...... 6 3
Chromium...... 6 1
Copper..........8 5
Molybdenum...10 38
Manganese.....1 0
Potassium.......2 1
Jan Richter
