Maybe all the independant dealers should pitch in and get amsoil to certify these oils so we can clear this up, LOL
![deadhorse.gif](https://bobistheoilguy.com/forums/images/graemlins/deadhorse.gif)
Quote:
Amsoil never claims to MEET or EXCEED any of the specs so it's sort of a moot point? The verabage is:
Quote:
Your wrong, AMSOIL does have a EGD oil in the ATP Saber Professional.
Quote:
Saber Professional is recommended for pre-mix where ISO-L-EGD, JASO FD or API TC is specified.
Quote:
ATP is not a EGD oil.
Quote:
NO, it isn't, LOOK carefully, NO WHERE DOES IT SAY: Meets these certifications. Amsoil's slick marketing only says: Recomended where the certified oil ratings are specified, You've been hoodwinked by the IMPLIED STATEMENTS and BOLD type of Amsoil's slick marketing. This why I don't care for Amsoil products, I dislike marketing HYPE. Sorry for the rant, but the consumer needs to know the truth. IMHO
Quote:
Klotz is a TCW3 CERTIFIED OIL and as such can not be EGD or JASO FC certified. One standard demands ashless oils(TCW3) the other demands low ash oils. From a formulation standpoint the base oils blends are also quit differant.
Quote:
I tried Amsoil 100:1 back in 2000 in my 1973 115HP and 9.8HP Mercury outbord motors. I did not notice any short term benefits from using the 100:1. There wasn't less smoke or less smell.
One thing I didn't like about the 100:1 was how bad it mixed with gas. I poured the recomended amount into a clear 5 gallon fuel jug and filled it up with gas. I noticed the blue Amsoil oil was still stuck to the bottom of the jug after it was full. I had to shake it real hard several times to get it to mix. The next time I filled the jug with about 1 gallon of fuel, then poured in the Amsoil and finished filling the jug. The Amsoil had poured threw the gas and stuck on the bottom. I also had to shake the jug to get the Amsoil to mix. This was a big negative to me. For an oil to be mixed as light as 100:1, it needs to mix compleatly by the time I'm finished filling up the tank on my boat, or my outboard might seaze.
I tried the Amsoil 50:1 and it mixed like any other 2 stroke oil.
The best bang for the buck 2 stroke oil was Cabela's Semi-Synthetic. Which is also the same formula as Mercury Premium Plus. (they both had the same TC-W3 test # on the back of the bottle).
I like the smell of Klotz the best, but I dont think it worked better in my outboard.
Quote:
would of been nice to take a few pictures, ................ you never mentioned how many gallons of gas you ran through your 9.5 marine engine![]()
