Is this oil certified TC-W3?
Is there any independent data of Saber vs. Other oils?
Quote:
See if it's on the list here: http://www.nmma.org/certification/programs/oils/
If it's not? Doesn't mean it's bad oil, but I'd bet there is probably one part of the test sequence it couldn't pass. Amsoil would never admit it and double talk around why they didn't certify.
My personal experience with the oil in outboards was it was fine on motors that didn't troll or idle much. If they did they would foul a plug. This wasn't just my motor but everyone I know who used it.
Quote:
This was before they renamed it Saber, but amsdealer tells me it hasn't changed.
Quote:
So are we to believe that Amsoil knows more about what oil standards are applicable to outboard motors than the MFG of said motor?
Truth is Amsoil AIO is not formulated to the standard and will not pass tcw3. Incidentally I tested a large quantity of AIO vs Yamalube 2M in identical outboards. The AIO smelled less, smoke was about the same and the motor ran on 2M was much cleaner internaly.
Ditto with the 100:1 oil. There is now way a 100:1 oil will pass the FD test as portions of that test are ran at a 16:1 mix ratio. Further I have tested the last generation 100:1 beofre saber and didnt find it too appealing.
Quote:
AIO has been gone for 3-4 years and you haven't tested the latest outboard 100:1 product. So why are you guessing on the quality of the new stuff?
Quote:
Your right, in that Amsoil 100:1 would never pass such a test, and its for this reason that Amsoil does not sell a EGD, or FC oil save Interceptor, which may or may not pass the tests.
