Originally Posted By: LeakySeals
Agreed, whatever people think needs to be done, do it. I never needed to or wanted to replace a waterpump on any car I've owned since my first car in 1980. Some cars had almost 300k. I know people that had replacement for a rattle, some weeping through the hole. But nothing catastrophic like yours. I think your replacement pump was defective or inferior china product, and you would not have had an issue if you had just left the original which was fine. But whats done is done, I hope you will have no further problems.
It depends upon the engine. A water pump replacement on a small block Chevy is fairly easy, and not labor intensive. Changing a water pump buried behind a timing belt is very labor intensive, and not always easy to do. Sometimes special tools are required. I don't know about you, but after replacing a timing belt, I am not going to trust a original water pump with 200K miles on it. I have seen more than a few that have leaked coolant on to the timing belt, ruining it in the process. Now this would not be a big deal if all engines were non interference designs, but they are not. Rebuilding a head or change a water pump? I'm going to change the water pump.
The vehicles you have listed in your signature all have timing chains. That is a different story. Changing the water pump on a 1ZZ is not that difficult. And generally (except for the Chrysler 2.7 V6 and the GM 2.2 ECOTEC which have water pumps driven by the timing chains) most chain timed engines use accessory belt driven water pumps, so their failure usually does not do any other damage.
