Amsoil Nanotech Full-Flow and Bypass Filter Particle Counts...
CA
A member of BITOG, SyntheticShield, has a Pontiac GrandPrix running Amsoil 10w30 and an Amsoil full-flow and Amsoil Bypass Element in a BMK-13 Bypass system. His initial used oil analysis post-Auto-RX is posted in the used oil analysis section.
Within the next month, he is due for another oil/filter change and oil sample. Since the new Nanotech Full-Flow and Bypass Filters are now available, he can drain out his current oil, refill with new Amsoil (of your choice), and install a new Amsoil Nanotech Full-Flow and Bypass Element.
For those of you who are interested in evaluating the performance of the Amsoil Nanotech filters, this is your opportunity. We can all “chip-in” a few dollars each for a particle count every 15K or so, so that we can see the performance of the Nanotech Full-Flow and Bypass filters working together. A Particle Count from Blackstone costs $19.50, so it doesn’t take many donors for this to happen.
Anyone interested? Comments…Comments…
Howe long has he being doing particle counts so one can compare results with other brands of filters he's had on the vehicle?
