Amsoil MTF mixed with Honda MTF
Richmond, BC, Canada
Hi! I just wanted to ask if it is ok to mix the amsoil MTF with honda oem MTF? I just had my car serviced today and got my MTF drained and filled.. The tech actually added the 2qts of Amsoil MTF i had into their MTF Pump that still had OEM honda/acura MTF in it.. Is this alright? Thank you!
I'm pretty sure it will work, my only concern would be if you have a problem the Amsoil warranty is not going to cover it since the fluids are mixed. That will probably be the case for Honda as well if there is still a warranty in effect. It would be best to do a complete drain and fill, and not mix fluids.
An mt takes so little fluid, I'd do a drain, fill, drive (if up in the air, do it like that), drain again and do a final fill.
@Hounds Thanks! Sorry posted a comment on that thread.. didnt realized it was you who posted the link.. my bad!
