AMSOil MT oil for Ford spec ESE-M2C39A (SAE 50)
Oak Harbor, Wash.
(Three attempts made using the AMSOil online/web form, no response :( )
I have a 1973 Ford F600 truck, 361 FT engine, 23,000 GVWR.
The transmission is a 5-speed Clark 282V36.
My understanding is that oil spec for the transmission is SAE 50, Ford spec. ESE-M2C39A for >0°F operation. From the Shop Manual:
Which AMSOil product is most appropriate?
MTG ?
CTL ?
FTF ?
I am led to believe that the unit required ~6 quarts for a fill. Thoughts?
I received an email reply to my second online inquiry to AMSOil (four days later):
You can use any 50-weight engine oil like the Premium Protection 20w50 or Zrod 20w50. That spec is obsolete, but it is just a 50-weight engine oil.
Hmmph. That's not very satisfying, esp. references to "weight".
It would be informative if you also post your original
question.
A 50 grade engine oil has a range of kinematic viscosity which falls into the SAE gear oil 75W90 classification. See this viscosity read-across chart.
here is a list of MTF's that would qualify:
G. The next higher viscosity MTLs in the 14-17 cSt (SAE 75W90) range would be:
1. Amsoil MTG
2. Redline MT-90
3. Castrol Syntrans Multivehicle 75W-90
4. Castrol Syntrans Transaxle 75w-90
5. Ford XT-75W90-QGT (Carries a GL-5 rating as well)
6. Ford MOTORCRAFT® Full Synthetic Manual Transmission FluidXT-M5-QS
7. ACDelco 10-4059 GL-4 75W-90 Manual Transmission Fluid
8. RAVENOL TSG SAE 75W-9
9. LIQUIMOLY 75W-90 GL4
10. PENNZOIL 75W90 GL-4
11. Motul MotylGEAR 300 GL-4/GL-5
12. HPL Manual Transmission Life 75W90 16.8 cSt
from
https://bobistheoilguy.com/forums/threads/updated-list-of-mtfs.383388/
question.
Sure. The question I asked AMSOil via their web form (twice) is what posted at the top of the thread.
"A 50 grade SAE gear oil has a range of kinematic viscosity which falls into the 75W90 classification."
Yes, sure; I did search before posting, but Thanks. You won't know the education level of your audience, so that was obligatory, and others may happen by and take note too.
The question I posed to AMSOil and now to you (all) is: which AMSOil product is best suited for this application, given the specific application info I provided and Ford's original -- and now obsolete -- spec.
AMSOil's emailed reply is not really helpful, IMO, but I suppose the single person whose assigned task it is to deal with the input from a web form is often not willing to go that extra mile to provide the information I thought I clearly requested. "Three products by your firm: which one is best?"
Really disappointed, as a PC for over two decades. Maybe I should use older technology and use the phone.
MTG ?
CTL ?
FTF ?
Amsoil MTG or Amsoil FTF
I think the MTG will shift better, but I have no direct experience with that 5 speed transmission.
You live in Duvall, I lived there 16 years. Have we met?
Thanks, Pablo. I was leaning toward the FTF.
We conversed (via email I think) in 2017 about my E300's rear diff (a two-year-only MB), but we've never met in person, and as a longtime PC I always stocked my private inventory direct from AMSOil. I was in Duvall 2010-2022.
I moved to Oak Harbor in 2022, and haven't updated all the probably 50+ profiles on various forums yet; I'll go do that here now.
