Amsoil Injector new oil?
Madiganistan/Chiraq
Amsoil Injector
Much cheaper than Interceptor...
And even cheaper than the old blue HP injector/marine stuff...
not sure what exactly this should be used in? not as good as interceptor for air cooled and not as good as hp marine for boats...?
AMSOIL Synthetic 2-Stroke Injector Oil offers the convenience of one formula for the tough conditions of all two-stroke recreational equipment requiring NMMA TC-W3 and API TC two-stroke oil.
Basically use it in any motor that requires TC-W3 2-Stroke Oil.
I just might by a gallon and use it in my autos and lawn equipment as well as my Generac 5500 generator. @ 1oz per 5gal I gallon will last almost 2years. $22.75 is not a bad price for a gallon.
I have a 93 safari lc. Rod bearing failure at 1200miles.
factory recall defective needle bearing.
used ski-doo mineral before overhaul.
rebuild included pistons/rings, all bearings/seals/gaskets, head milled, and waterpump. rebuilder set the pump rich and set to run premix too the first few tanks of fuel. he said to use semi-synthetic i bought spectro brand he sold. wouldn't full synthetic be better?
Would this be amsoils best oil or do they have a better line for injector sleds..
ken
ken
I almost hate to recommend something in this situation. So after the recommended fix have the engines been holding up well? I do like the mech's recommendation. Maybe premix the oil 100:1 using Amsoil's Saber, then use the AMSOIL Synthetic 2-Stroke Injector Oil.
