I'm the process of building my '94 Honda Elite (Dio). This info might not mean anything to most people here but the build is as follows
-Polini Corsa 72cc BBK (this is a ported cast cylinder with aluminum head)
-Naruka manifold
-Polini 24mm carb
-Oil injection removed
-Expansion pipe
-CVT work. Variator, clutch, secondary final drrive gears.
This is an aircooled engine which should be running in the 10-11.5k range with head temp 280-350 deg.
I am trying to decide on running Amsoil Interceptor or Dominator at 32:1
With the previous build I was running Interceptor using the oil injection.
Given RPM, Temp, Etc, what would be the better choice to run? I've heard the Dominator burns s little dirtier than the Interceptor which is not necessarily a big concern of mine. In don't expect to put 1000's of miles on it each year, but I want to extend piston and ring life as long as possible.
Any suggestions or help?
-Naruka manifold
-Polini 24mm carb
-Expansion pipe
