Always appreciate your input, if you look at #1 and 2nd pict, it says Honda Z1 on the back and hence the questionI don't see where Honda is on the recommended list on those bottles. I'd go to the Amsoil look up and input all the information for the Honda vehicle and see what is recommended. If what you have there isn't recommended, I'd pass. That said, I'd have have ZERO issue using the recommended Amsoil ATF for Honda vehicle with rec for DW1 or Z1.
This from someone that has long used MaxLife FSMV in my Hondas, many thousands of miles, and completely satisfied. If you're interested beyond that, I'd suggest you go read some of the member's successful anecdotal experiences (there are many), using other than DW1 and the highly criticized Z-1 in their Hondas.
Back to specific topic, Based on what I see, I'd pass on using it in Honda AT specing DW1/Z-1.
It would be a fantastic option for Toyota P/S systems, which call for ATF.Use those products in an old pick-up truck.
Or my pal's '97 F-150.It would be a fantastic option for Toyota P/S systems, which call for ATF.
I stand corrected, missed it. Yeah, definitely wouldn't use the second one. The first one, full synthetic likely ok imo. That said, your vehicle(s) and your confidence level.Always appreciate your input, if you look at #1 and 2nd pict, it says Honda Z1 on the back and hence the question...
Both of them or just #1? Thank you @PabloShake it well and use it.
In your cars? No problem at all. Zero.Both of them or just #1? Thank you @Pablo
Before I saw your posts I was going to be the contrary one and say it’s fine to use as well.Shake it well and use it.
Thanks, curious to see if one from 2010-11 has the same label? It might be from that era then!I have a bunch of the old stuff lying around that I used in my S4 tip. This was before it was the Signature blends. Not 100% positive without looking but they might be similar to the first pic. Got it probably around 2010-2011.
If he said it, am good and will use with confidenceIn your cars? No problem at all. Zero.
