AMSOil ATF - Please advise!
betcha the Misub. dealer shops are watching these transmissions like hawks for failure with Brand X Maple Syrup unauthorized unspec'd ATF
we are fast approaching the sealed warranty dealer service only auto transmission
There is some kind of error here, but..... We’ve looked into the Dia Queen ATF J2 situation you asked for and have come up with some info. Are you 100% sure which transmission you have?
Mitsubishi uses a couple types of transmissions in their Outlanders. 1. A regular step transmission JF613E that uses Dia Queen ATF SPIII (AMSOIL ATF) and 2. A CVT transmission JF011E which uses the Dia Queen ATF J2 (no AMSOIL product). This information has not been formally confirmed but looks as if it may be the reason for the confusion.
Quote:
Quote:
Quote:
it's a Jatco JF011E transmission shared by the Dodge Caliber,Jeep Compass,and the Jeep Patriot.
http://www.jatco.co.jp/ENGLISH/PRODUCTS/cvt.html Mitsubishi calls it a INVECS-III and calls for SP III.Dodge specs ATF+4.
No.
The 07 Outlander FWD uses the Jatco JF613E transaxle which has a transmission code of F6AJA. The AWD model uses the W6AJA transaxle.
I made an error. I sorry
It seems I spoke to soon.I was picking up some brake pads and my Mitsubishi parts dept and JF011E is listed as a trans for some 07 Outlanders.
Quote:
No problem... Its all good. CVT transmission (INVECS) didnt come to states as 2.4 ltr didnt make it either.
Its 3.0 SOHC with 6 speed transmission.
Okay now back to the topic... Manual says
Dia Queen ATF - J2
so dealer was right... SPIII as mentioned by AMSoil is incorrect and they need to fix their application guide.
Not that their univ atf is not applicable. I havent gotten any info yet from amsoil tech.
But I am a bit reluctant now... I think I will stick to the dealer for transmission service. With the truck being new and all...
Sounds like the manual is in error - if you DON'T have a CVT transmission, then you can use Amsoil ATF.
Thanks Pablo... Appreciate your help. I agree.. There is something fishy somewhere. I dont have the CVT for sure.
No.
You are absolutely right... Just double checked again..
Transmission's official name: W6AJA-1-F1ZA
Recommended fluid: Dia queen ATF - J2
Apparently this fluid just started coming in to dealers three months after the launch.
Thanks everyone!
So I guess I can add that the AWD W6AJA uses the J2 ATF for whatever reason.
3. AWD W6AJA (W6AJA-1-F1ZA) uses the Dia Queen J2 ATF (no AMSOIL product).
PABLO, what is your take on Amalie Universal Synthetic ATF. Here is the link to its specs. Iam intersted in the T-IV spec. Let me know what you think.
http://www.amalie.com/specs/index.html?pdf=4b_trans_cvt.pdf
or
or
