Amsoil ATF vs Pentisol CHF 11s
canada
Car: MINI COOPER S 2002:
At 56,000 km an independent service mechanic replaced a Power Steering line, bled the original PS fluid and re-filled using Amsoil ATF.
The MINI PS fluid cap and MINI Spec states: Use only Pentosin CHF 11S
I drove the car for 1.5 years (mostly non-winter driving)for a total of about 10,000 km with the Amsoil ATF. I did not notice any problems until recently in -25 degree Celsius, when I noticed an issue with PS assist and a high-pitched whine in my PS pump (which goes away when the outside temp is -10 degrees Celsius.
Question: Do you think the Amsoil ATF may have caused damage to the Power Steering Pump? And/or the PS Rack? Both are expensive repairs. I have been advised by MINI to bleed the PS Amsoil ATF fluid ASAP, replace with Pentosin CHF11S and see how the pump and steering system responds, and try this a couple of times (to avoid potential issues about mixing the two different fluids and risk causing seal problems). The independent mechanic is willing to do this. I am looking for any further advice on:
a. Comments on the key differences between these two fluids?
b. What the likelihood of damage, if any, might be using the Amsoil ATF instead of Pentosin CHF 11s? (esp to the pump and/or steering rack – both of which are expensive to replace)
c. What is the best course of corrective action?
1. Mini indicates on the PS cap: USE ONLY CHF 11S (Pentosin product)
- dark green
- density 825 kg/m3
- Viscosity
100Deg: 6.0 mm2/s
40 Deg: 18.7 mm2/s
-40DDeg: 1100 mm2/s
Vis Index: 313
2, Amsoil ATF
- red
- density: ?
- Viscosity
100Deg: 7.6 mm2/s
40 Deg: 38.9 mm2/s
-40DDeg: 9800 mm2/s
Vis Index: 168
ATF regardless of brand synthetic or not is incompatible with Pentosin CHF 11S.
CHF 11S is synthetic mineral oil,ATF is petroleum based.
CHF 11S is also used in some Citroens central pneumatic systems,when any other fluids are used the seals let go in time.
I would flush the ATF out completely,not with a turkey baster but a complete line off flush with CHF 11S.
If no leaks crop up later you got away with it but don't be surprised if it does eventually.
I doubt the Amsoil ATF caused any problems, -25°C is pretty cold - maybe the Pentosin CHF 11S would have made a noise as well.
The fluids aren't that different, although the Pentosin CHF 11S does look like Amsoil ATL, not ATF and frankly I don't believe the stats posted. VI of 313? I'd love to see the HTHS #. It's a very thin fluid.
BTW Amsoil recommends PSF not ATF.
AMSOIL power steering fluid would definitely have been a better choice.
I do believe Pentosin stats. Its a hydraulic fluid, not an ATF or motor oil as such doesn't need to meet oil/ATF requirements. And, at $22 a quart, its gotta be 2-2.5x as good as Redline/Amsoil/Mobil1. Just look at the -40c spec and you'll see why the VI is 300+
http://www.pentosin.net/pressreleases/CRP-116_Pentosin_CHF11S_V3.pdf
http://www.pentosin.net/pressreleases/CRP-116_Pentosin_CHF202_V2.pdf
The only legit competitor also has a high VI:
http://www.opieoils.co.uk/pdfs/fuchs/fuchs-titan-zh-4300-b-synthetic-hydraulic-fluid.pdf
Gunks green-PSF equivalent($1 an ounce), no data specs but read the formula which is similar to the Pentosin/Fuchs:
http://www.gunk.com/prodinfo/M2712SYN.PDF
http://www.gunk.com/msds/M2712SYN.PDF
http://www.pentosin.net/pressreleases/Pentosin CHF11S Central Hydraulic Fluid 1-11-11.pdf
http://www.pentosin.net/pressreleases/Pentosin CHF202 Central Hydraulic Fluid 1-11-11.pdf
Originally Posted By: Pablo
True enough - a very thin hydraulic fluid.
Very thin, meaning about the same as Amsoil ATL and any other 6cSt fluid.
Either of the CHS fluids would blend OK with typical ATF fluids so there's no harm in mixing (there are several TSBs floating about that state this). Also, by the looks of the MSDS, the CHF 11s is a Group4 synthetic while the CHF 202 is a Group3. That might help explain why the 11s has slightly better specs.
Just digging up some info on the Pentosin CHF and thought I should add.
CFS 11S is primarily PAO based fluid
CFS 202 is PAO/HC based fluid
Both are high VI 300+
CHF IIS @ -40C is 1100cP
CHF 202 @ -40C is 1354cP
At 100C both are about 6cSt
Both of them are hydraulic fluids NOT ATFs.
As someone pointed out earlier material compatibility would be one concern
Unless the vehicle mfgs released a TSB saying that it's OK to 'top up' or mix with Dexron3 (or similar) fluids. Then I think it would be OK to mix.
The MSDS for CHF 202 shows that both PAO and refined HC are <20% so it's sounding more like a semi-synth. Not sure that's possible with the high VI they have.
