Amsoil ATF and Magnefine
Texas
My 2000 Odyssey is currently at 212k miles. 100k miles ago, I replaced most of the ATF in the Odyssey with Amsoil Syn ATF because I understand that these transmissions are prone to failure:
http://www.amsoil.com/shop/by-product/tr.../?code=ATFQT-EA
I followed the replacement procedure that requires you to detach a transmission hose and I feel that the procedure is far superior to the 3x drain refill method, I didn't drop the pan because the Odyssey transmission doesn't have a pan, and I drain the transmission hose about one quart at a time so that i can replaced the fluid one quart at a time:
http://www.workablewebtools.com/site_files/103/File/TSB_ATF_and_Filter_Change_Procedures.pdf
Of course, I put in a Magnefine inline filter as well and I didn't change the filter for 100k miles. When I removed the Magnefine filter, I suspect without conclusive proof that it is still working because the ATF that flows out from the output port of the filter is still much clearer / cleaner than what flows out of the input port. I am actually very impressed with the Amsoil ATF because after 100k miles, the liquid is only dark red / slightly brownish and I suspect it could go further than 100k miles. I believe that the Magnefine filter also did an awesome job at filtering out harmful metals.
This time around, while I changed the ATF, I am using the newer fuel efficient version of Amsoil's ATF that supports the newer Honda DW-1:
http://www.amsoil.com/shop/by-product/tr.../?code=ATLQT-EA
I hope that my Odyssey transmission will last another 100k miles and I will report back when my car reaches 312k miles.
That's pretty impressive for one of those transmissions! It looks like you have the right combination there.
thanks for sharing, very impressive indeed.
I drain and fill my trans at the end of summer after 20k miles. pls cut the filter open when you change the filter if possible.
I might add the filter to the ridgeline :-)
amsoil makes perfect sense after warranty is up. it will probably be cheaper if you buy a case of amsoil compared to honda atf.
